Page 6 of 6
Re: notnilc20's 1986 ae86 Hatch build/restoration
Posted: Fri Jan 19, 2018 3:30 pm
by notnilc20
scalpel wrote:Any update? Miss watching the eps.
Maybe in a day or so...
Posted: Fri Jan 19, 2018 3:32 pm
by scalpel
Just wanted to pressure you into making an update
Posted: Sat Jan 20, 2018 9:27 am
by notnilc20
Been a few weeks....finally another video. Trying to get everything to fit right before primer and paint.
https://youtu.be/l9g1HaPqHrg
Posted: Wed Feb 07, 2018 11:59 pm
by broku-hachi
whats up, I was wondering if you would be able to help with my A/C installation.
I have been working on a sr5 to gts swap. I am trying to piece together parts necessary to install a A/C system but I'm a bit stuck.
I currently have:
-complete sr5 a/c system ( lines, evap, compressor, condensor, etc.)
-Kouki gts evaporator w/ amplifier
-Non P/S 4ag compressor mount
-and all of my wiring is from a zenki gts
I was wondering if you knew of any differences between the kouki and zenki a/c compressors and a/c wiring harness?
Also what did you do about the A/C idle up and what parts are necessary?
thanks for any help.
Posted: Thu Feb 08, 2018 11:50 am
by notnilc20
broku-hachi wrote:whats up, I was wondering if you would be able to help with my A/C installation.
I currently have:
Did you catch this video?
https://youtu.be/WLSNISShtTIMake sure to read in the description as I talk about some of the lines differences that I've found.
As for the compressor, does your engine harness have the 2 wire blue plug for the pressure safety switch on compressor and the black power wire for the electromagnet clutch? If so, the compressor in the link on that video should work...but since you have no powersteering, I'm not sure what that will change...but they do sell a non powersteering version as well on that same page I believe.
Not 100% sure about the ac wiring harness (under dash with the 2 relays etc) and any differences....but their shouldnt be any differences.
Ac idle up....i had a ac idle up valve in my box 'o parts luckily that I used. It hooks up to the vacuum via intake tube going to int. Manifold and electrically hooks up via a plug on the engine harness.
Let me know what other q's you have.....
Posted: Thu Feb 22, 2018 8:08 am
by notnilc20
In this episode i finally get the body parts in primer and block sand..... also i get myself a gift and install it as well...
https://youtu.be/A3Y9j5iYfm4
Posted: Tue Mar 20, 2018 8:09 am
by notnilc20
That's right jam-packed into 1 full episode painting and installing the jblood rep body kit. I need say no more.
Enjoy!
https://youtu.be/Y-k4fvxDvgs
Posted: Tue Mar 20, 2018 11:31 am
by aukword1
looks really good, paint came out nice!
Posted: Tue Mar 20, 2018 5:38 pm
by notnilc20
aukword1 wrote:looks really good, paint came out nice!
Appreciate that man.
Posted: Tue Mar 20, 2018 10:41 pm
by shagymc
Hell yea! Paint looks great! Killer work!
Posted: Wed Mar 21, 2018 7:29 am
by notnilc20
shagymc wrote:Hell yea! Paint looks great! Killer work!
Thanks a lot!
Posted: Fri Apr 13, 2018 9:23 pm
by notnilc20
It's getting ever so close to the finish....join me in this episode as I tackle the tedious and much repetitive task of wetsanding and buffing (dont worry I edited the video). Plus I remove the runs from the paint and install the zenki GTS decals!
https://youtu.be/JK3SKc8Jbe4
Posted: Thu May 03, 2018 7:41 pm
by notnilc20
Finally get to do some fun stuff. Racing pedals and a dash overlay!
https://youtu.be/P5KXSw6iYKQ
Posted: Thu May 03, 2018 9:44 pm
by broku-hachi
Yo this just popped up on my fb feed.
https://portland.craigslist.org/mlt/pts ... 57014.htmlheadliner for a coupe but it might work with a little ingenuity
Posted: Fri May 04, 2018 9:20 am
by notnilc20
Thanks a lot....might give it a go.
Posted: Tue Jun 19, 2018 10:57 am
by notnilc20
Measuring pinion angle and install an adjustable panhard or lateral bar then make some fine tuning adjustments to center that rear end.
https://youtu.be/qtbPNnJs7Mc
Posted: Tue Jun 26, 2018 1:35 pm
by notnilc20
Here it is all in one episode. Setting timing per the Toyota factory service manual. Also, I set up the throttle body and TPS (throttle position sensor).
https://youtu.be/ecu53wgRR-8
Posted: Wed Jun 27, 2018 5:23 am
by davew7
One suggestion on the setting up the TPS. The bottom screw attaching the TPS to the TB, can be a real PITA when it comes to access. $hit can the stock Toyota screws and go to your local hardware store, in my case Home Depot and get two Allen Socket screws. They should be 4mm - 0.7thds x 12mm lg. Life will be so much better. DaveW
Posted: Wed Jun 27, 2018 7:12 am
by notnilc20
davew7 wrote:One suggestion on the setting up the TPS. The bottom screw attaching the TPS to the TB, can be a real PITA when it comes to access. $hit can the stock Toyota screws and go to your local hardware store, in my case Home Depot and get two Allen Socket screws. They should be 4mm - 0.7thds x 12mm lg. Life will be so much better. DaveW
Yep good suggestion...i keep meaning to do that but it always slips my mind when I'm out and about.
Posted: Mon Jul 16, 2018 9:35 am
by notnilc20
Can't beleive it's been 54 episodes now. In this one I install an aftermarket head unit and speakers. Lotsa fun!
https://youtu.be/1qxglsnMLFY
Posted: Tue Jul 24, 2018 7:43 am
by notnilc20
This is how I measure and adjust camber on my ae86.
https://youtu.be/3ywE1bxcn7Q
Posted: Sun Jul 29, 2018 2:06 pm
by scalpel
Great job!
Posted: Fri Aug 10, 2018 8:11 am
by notnilc20
scalpel wrote:Great job!
Thanks my bro.
In this episode i'm installing the side mouldings and rear window trim....thanks for watching.
https://youtu.be/sAqK62kiqCE
Posted: Thu Aug 16, 2018 2:13 pm
by notnilc20
In this installment I replace the rusted fuel tank, fuel pump, and fuel filter and clean out the lines. Thanks for watching.
https://youtu.be/FdRuKWdRGDs
