Project AE86 aka the never ending project
Re: Project AE86 aka the never ending project
Did you try to manually rotating the crank by hand to see if it will cycle freely?
yes, and it wont. 90% sure I have a bent rod or rod's.
I am looking for a new longblock, but I am also bidding on a house, and if that falls through I will be moving back to Northern California, and my funds are tied up in too many things to spend more on this car if it ends up being costly...
not to mention I still dont know why the injectors hydrolocked the car...
1994 4runner (The truck)
- maxpham
Oh boy! you were doing so well too! If you need to borrow a cherry picker, I left mine with my brother in Ontario. Let me know, a car like that should not be parked in garage.
hey marley i noticed you had to cut down your console. check out these JDM consoles might be something to consider
Max- i got my friends today, so we are pulling it. but thank you so much!
gagoosh- thanks i might have to look for one if they are cheap
Just got my first day off. so I started working on the car. No i did not get to see it flash, but maybe the bulb i was using was to big, it was a old brake light bulb....next time I will use a LED, but when I test the injectors they do fire.
well I plugged the CAS and the injector clips on, held the injectors out and turned the car to on (mind you the head is off the car). Then I turned the CAS, the first turn, it would fire all the injectors or sometimes two at the same time? is this normal? after the first turn if I kept turning it it would fire in the correct order one at a time with a good spray pattern and no leaks at all....
I am still confused how it leaked in the first place. The intake manifold was full of fuel, pulled the head, and the block out, drained the oil, and I am pulling the pan in the morning and looking at the bearings and the rods etc.
marley4us is online now Report Post Edit/Delete Message
pulled the beast out
good by SR
I think this might be the problem lol!!!
Put everything else to the side
Even gave it a little color
Got new (used) rods, and BNIB rings
good by SR
Im giving it my best to keep her and make her go!
Went to Toyota Fest today, once we left, started rebuilding the whole motor.
With adequate supply of water and beer in the tool chest.
Problem child was replaced
with a New used rod
Brand New rings where installed
Wrapped my Downpipe with heat wrap.
Installed a SARD Fuel Pressure Gauge I had laying around
Honed, then Installed the pistons and rods back into the block.
Then Time just to reinstall and torq down everything.
Lol this is what happens when a bunch of hot drunk girls (my neighbors come home at 1am).... car gets abandoned lol....tools still in place!!! lol
The Valve Cover got fuel on it, and ruined the paint, so I sanded it down, and gave it a new look.
Might as well make use of the sticker I have to paint over now... with A touch of color
Peel it off
All Done, Going to Install it back into the car tomorrow... fingers crossed.
here are some sexy pics of the car to end with for the day with the Battle-Garage One off Carbon Fiber Fender flares!
Fenders need to be pulled more
with a New used rod
Peel it off
Worked a 16hr shift today, then installed the motor, got it in, just need to wait for my o-rings to come in tomorrow and test fire her up.
Getting the beast in
Its in! what a good feeling hahahah it always is
Trans mount in
Drive shaft in
Valve cover done, hope to have it running tomorrow.... fingers crossed.
Trans mount in
Drive shaft in
- thehighflyin12
NO!!!! I NEED MORE!!! Do you have any updates?
1985 Toyota Corolla GTS Hatch
2007 Nissan 350z Enthusiast
1993 Mazda RX-7
1975 302 swapped Datsun 280z
1993 Mazda RX-7
Glad you got it back together so quickly. I would've put my crap for sale with gusto if that happened to me lol.
Knockoff Crew member #0001
Kool ,, nice progress ,,,,,,,, when i came threw, the motor was out,,,,,, u guys are fast...hope it runs,, good luck
Thank you all for the support! I really needed it, I almost junked the project....
She is alive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.youtube.com/watch?v=n013nJsB ... e=youtu.be
I am so freaking happy!!!!!!
Love how I redid the valve cover etc it turned out better then I thought it would!!!
List for tomorrow:
Get SR slave cylinder and line, drive car to my buddies and built the exhaust!!!! Finish dash so speedo, tach, temp works for sure! Then I am done!!!!!!!!
List for tomorrow:
- maxpham
congrats! just saw the video!
I just watched the video too! Congratulations!
Now go drive the hell out of it; you deserve it!
Sweeeeeet!! congrats :3
btw, thanks for giving me another song to listen to heh (MONKEY MAJIK / 空はまるで ) xD
Congrats Ian!
Now get out and drive that thing!!!
-John
-John
Maxpham- thanks!!!
Yellow snow- I did for the first time, though I need to finish the exhaust before I smash on it!!!
TD86- heheh glad you liked it! you should try listening to M-flo, monkey majik, gagle they are all good too!
John- thanks!!!!!
I got a s14 slave cylinder, and lines for 20 bucks. Cut it to fit the AE86, and flared the ends, the nissan thread pitch is the same as toyota so it bolted right up! Got to take the first drive today!
Finishing the exhaust tomorrow and the E-Brake and its done!!!!!!!!!
John- thanks!!!!!
good job ian
Told you this car is a money pit!!!
but youll be done soon and enjoy your car...
Bnic- ya man ur right! but my price chart is actually not that bad, I have about 7500 invested, but I resold 2000 in parts, so I only have 5500 invested into this ae, plus a million man hours lol! I hope to get it painted if all else goes smoothly before I move
I did the VW sunshade mod to the AE86, with a little of my own changes to it.
Part number from VW 3c0 064 360 its only 15 bucks lol!!!
Come with all the hardware too
Pull off the speaker covers, this is where I made a bracket out of alum to space it out so u can put the covers back on.
Use some self tapping screws
Put the covers back on
put the oem clip in
and your are done
put the oem clip in
and your are done
Thanks another guy in club4ag posted it, its a sweet cheap nice mod.
Thinking about making a plate to cover up the intake manifold, might glass it in CF
HKS filter on, I need to lower it a little but its pretty much done.
Got the exhaust done today with xene, whole thing cost about 120 bucks to make V-Band and all!
since my garage does not have a 210 outlet we had to stick weld the tac welds then bring it to his place to finish it off.
Pile of steel
Cutting it down to fit proper
Downpipe and flex pipe tac welded
V-Band welded
Mid pipe
lol caught the blanket on fire
Midpipe continued
Brought it back to xenes to use the 210 self feeding welder, Not the prettiest welds but its all full depth and strong.
welding some hangers
Cutting down some pipe to make the angle for the muffler
Getting the pipe positioned under the rearend
Testing out angles for the muffler
Time to weld the pipes and bends up
welded
Started to make the flange and screamer pipe for the wastegate
Cut a piece of steel I had laying around
Used a piece of paper to mark out the wastegate bolt holes
Drill some holes
Pile of steel
V-Band welded
Mid pipe
Midpipe continued
welded
Drill some holes
v band awsomeness ,,, easy and clean!!!!!!!!Keep up the good wrk
-yeah got to love V bands!
Took her for a test drive, I need to post the video.... lol found a leak in the brakes lines, I need to fix tomorrow lol... it was fun having almost no brakes after letting into it hahahahahahahh
Exhaust looks clean! I dare to say that the muffler looks classy as well. Reminds me of the hks sport.
thanks, thats the style I was going for!
So the rims are crazy wide 15x10-38.... and even the flares just did not cover it enough, so I am going super saiyen, double dragon style
Those fenders.
Going to do the same origin lab with the front? Btw, didn't know I could find good music on this forum too LOL. Monkey Majik and m-flo.. so good ahaha
here is some more good music!
Gagle featuring monkey majik
http://www.youtube.com/watch?v=8h4Z6p7H-U4
Basi あなたには
http://www.youtube.com/watch?v=2nuQTbWV6sk
But ya I have the same origin lab CF fenders for the front, just forgot to tap em up before I took the pictures. I am going to cut the fenders tomorrow, rivat this all on and drive the car to paint this week fri or monday.
Basi あなたには
