Page 3 of 4
Re: My Corolla... Back Again
Posted: Sat Sep 21, 2013 9:03 am
by RuizXIII
Nice updates!
That Cressida is so cool. What are the specs on the wheels?
Posted: Sat Sep 21, 2013 1:30 pm
by Rue
Fronts are 17x9 + 25
Rears are 17x10 + 20
Posted: Mon Sep 23, 2013 7:16 pm
by Rue
Alright.... Corolla Updates!!!
Shooting to have the celica supra rear end finished in the next week or two. Bought almost all of the remaining parts that I'm missing... rear rotors and axle bearings. Just gonna buy the third member to axle housing seal and finish fabricating all of the mounts.
And once again I have a dead spot on my manual rack. When I pulled everything off of my car when I did the swap I tried to have my ae86 manual rack rebuilt. The shop I took it to said there was excessive wear in the middle of the rack. So I chased down an aw11 rack and had them rebuild that one. 2 years later I'm having the same problem. Sooooooooooo.... I'm starting fresh.
Right now I'm working on collecting parts for the outer tie rods I want to make for my rack. I've looked into Xcessive Manufacturing's outer tie rods and of course Techno Toy Tunings outer tie rods. I have problems with both. There's no way that either company is using a quality heim joint for the price they're charging and I'm going to be pissed when I have rattling/play in them after a year. I like that Xcessive made a tapered stud to match the taper in the oem steering knuckle but T3 sells their kit with a 5/8" drill bit and uses a 5/8" bolt. That's bullshite to me. A 5/8" bolt doesn't measure .625"... it's undersized. And when you hand Joe Shmoe a 5/8" drill he's going to end up with an oversized hole. That means there is going to be slop where with the tapered stud there wasn't any. Soooooooo... T3 is adding slop with the "use the supplied drill to make your hole match our BS bolt" and with the cheap heim joints.
The heims I'm buying are Aurora 5/8" LH blah blah blah and cost $57 per heim... link:
https://www.pegasusautoracing.com/produ ... oduct=3062I bought 5/8" shoulder bolts that measure .622" in diameter and will be drilling the holes in my steering knuckles with an undersized drill followed by a REAMER to hold tight tolerance... I don't want slop. I'll post up more as I make progress but total projected cost of the outer tie rods is $200 for a pair. Planning to pick up a Quaife QSR this time.
Shoulder Bolt...
5/8" LH Jam Nuts...
Posted: Thu Sep 26, 2013 4:48 pm
by Rue
Posted: Mon Sep 30, 2013 4:48 pm
by Rue
Posted: Tue Oct 01, 2013 9:34 am
by joel23
looks good... nice update....
Posted: Thu Oct 24, 2013 7:18 pm
by Rue
Posted: Tue Oct 29, 2013 5:59 pm
by Rue
Posted: Wed Oct 30, 2013 7:42 am
by rekik
I'm diggin this build. curious on that sleeve for your outer tie rods. wondering if i can get the specs or a link? thanks
Posted: Fri Nov 01, 2013 7:01 am
by Rue
Rekik... I sent you a PM. Call me
Posted: Fri Nov 01, 2013 4:35 pm
by marley4us
looking bad ass as always!
Posted: Sat Nov 02, 2013 1:18 am
by gazolorean
Awesome progress! Might have to come check it out sometime.
Cressida looks like it's coming along nicely as well
Posted: Sat Nov 02, 2013 7:25 am
by Rue
You know where I live so stop by. I'd like to see your 350z
Posted: Sat Nov 02, 2013 7:43 am
by R3sistance
rekik wrote:I'm diggin this build. curious on that sleeve for your outer tie rods. wondering if i can get the specs or a link? thanks
I'd love to know the specs on the whole outer tie rod set up as well. That setup looks strong!
Posted: Sat Nov 02, 2013 6:33 pm
by Rue
The reamer came in today so I'll have this finished this week. Again... the shoulder bolt measures 0.622" so I bought a reamer that measures 0.6225". Just big enough to be a slip fit and not a press fit. I can't wait!
For those who don't know this is what a reamer looks like
Posted: Sat Nov 02, 2013 6:47 pm
by DatGuy217
Hell yea man. You have the fellow machinist touch and mentality. Great build
Posted: Fri Nov 08, 2013 2:00 pm
by Chris-pee
Aaron's car was totalled yesterday. A moment of silence please.
Posted: Sat Nov 09, 2013 7:47 pm
by joel23
^^^^^^ i hope thats a joke man.....
Posted: Sat Nov 09, 2013 7:50 pm
by Chris-pee
Not a joke unfortunately. I'm sure Aaron will chime in.
Posted: Sun Nov 10, 2013 9:13 am
by Rue
Not a joke... the body is toast. Most of the Levin front end didn't make it. Only gonna part with a few pieces that won't swap over to the new project. Mark is getting my hood and grill for his rhd Levin coupe and I have a close friend interested in my redline taillights and carbon hatch.
All of the suspension and drive-train is undamaged. Bent one of my front wheels really bad but it's still repairable.
Gonna shoot to have everything tore apart this week to make room in the garage for the replacement body.
I'll call you in a minute Joel.............
Posted: Sun Nov 10, 2013 10:25 am
by tchybrid
Holy crap, so sorry to hear bro. Hope you are okay tho. Cars are replaceable, regardless of how much blood sweat and tears you poor into them. I'm sure the next project will be better, faster, and stronger. Good luck sir!
Posted: Sun Nov 10, 2013 11:39 am
by carbd7age
Dang.
Posted: Sun Nov 10, 2013 7:30 pm
by Rue
The most positive thing I can say about the whole thing is quoting Mark (mandm177)... "You did drive the shite out of that car."
I did... I put it together to drive; not to look pretty.
I was butt-hurt about if for the first day but I knew it was always a possibility.
Here's a couple of ugly pics of the new ugly chassis...
Posted: Mon Nov 11, 2013 6:09 am
by Clouds
Well, I hope something good can come out of this.
Posted: Mon Nov 11, 2013 2:51 pm
by Dustin
Let's not forget that his last Corolla came from humble beginnings. I'm sure to expect great things from this new one.
Posted: Mon Nov 11, 2013 2:56 pm
by Dustin
From that to this.
Posted: Mon Nov 11, 2013 8:34 pm
by Rue
I'm already getting a ton of help from my fellow ae86 owners. Joel23 is sending me a JDM Kouki Trueno grill and Thaison is setting me up with a JDM Kouki Trueno front bumper setup. I'm a happy guy!
Posted: Mon Nov 11, 2013 9:32 pm
by kendallspower
Ohno!
Posted: Mon Nov 11, 2013 9:33 pm
by kendallspower
Hope you're okay pal!
Posted: Tue Nov 12, 2013 6:26 am
by rekik
you got this!!!
