Fast forward several years later and I had get a quarter panel and hood from the junkyard (the car rolled down the hill into the back of my best friend's dad's Suburban, rebuild the motor twice (destroyed the pistons after 10,000 miles after the first rebuild), bought a nice exhaust from AE86Kai and finally bought a MSPNP2 from DIYAutoTune here in Georgia last year. I had them also convert the car from MAF to MAP and since May when I got the car back from them, it's been quite a while since I have driven the car. I'm am still getting the MSPNP2 tuned by Russ from DIYAutoTune (also Russ on here as well) to work out a couple little nagging problems. At the very least, I have been driving it on the weekends and it's been a blast. The only thing I can ask for is that the weather warms up so I can do more work on this car.
Current setup so far:
Cast Iron Factory 7-rib 4A-GE block with 0.020” (0.50 mm) overbore
Factory Connecting Rods
Fel-Pro OEM Replacement Head Gasket 1.2 mm
Wiseco Piston/Ring Set; 18 mm connecting rod wrist pin/40 mm crankshaft - K533M815
0.010” (0.25 mm) undersize main bearings and rod bearings (Clevite 77 OEM replacement)
Web Camshafts 577 Grind Number; .033” (8.382 mm) valve lift; 252 Duration (226 @ .050)
HKS valve springs – 2201-RT004
T3 adjustable cam gears
T3 short shift kit
Balanced rotating assembly (crankshaft, connecting rods, flywheel) to 8000 rpm
AE92 flywheel and clutch kit
OBX-R header 4-1
Custom mandrel bend 2.25" catback with APEXi WS2 (I think) muffler - over diff
Fel-Pro replacement exhaust gasket: 60496-1
K&N universal filter
Electric fan conversion
OEM replacement fuel injectors for bluetop – GP Sorenson
MSD SCI ignition box
MSD tach adapter 8910EIS
MSD Blaster 2 coil
NAPA/Belden spark plug wires
AEM UEGO wideband oxygen sensor
Sunpro mechanical oil pressure gauge
MSPNP2 installed by DIYAutoTune
14x7 Toyota Supra wheels
