I've got a few build threads so I've compiling all the important stuff into this thread!
I imported a vehicle form Japan. A 1987 Toyota Levin.
Here is the parts list I got on her so far.(translated from Japanese, so some parts might sound funny)
Engine:
Carburetor: SOLEX50
Intake Manifold: TODA Racing
Linkage NISMO
Exhaust Manifold: SECTION 4 (45 Φ -60) isometric all stainless
Camshaft: TODA Racing IN: 288 OUT:304
Camshaft pulley: TODA Racing
Valve spring: TODA Racing strengthened spring
Clutch: ORC Super single (metal)
Head gasket: TRD
Engine head: Intake/exhaust Port and Polish
Decked Head
Crank Pulley: Single
Oil Cooler: Maybe made in USA
Engine mount: TRD
Transmission Mount:TRD
Transmission: TRD 3-speed cross mission
Differential finial gear:TRD 5.375
Differential LSD: TRD(Initial torque up)Sim up (early period)
Quick shift collar: Brass
Ignition ECU: KOEI Racing CDI
Clutch hose: EARL'S Stainless steel mesh hose
Muffler: RS.S all stainless
Coil: WAKO
Front Suspension:
TOKICO adjustable coil overs
Cusco Pillow ball upper mount
Cusco Roll center adjuster
Cusco Pillow ball tension rods
No name Pillow lower arm
GAB Stabilizer Pillow type (Adjustable)
Nagisa Auto Front Frame
Rear Suspension:
GAB stabilizer
Lateral Rod Pillow type
Lateral Rod reinforcing bar (Cusco)
Traction bracket
Rear strut tower bar triangle type (Cusco)
Do Luck REAR CROSS BAR
Rear control arm TRD Bushing strengthening
MSC:
FRP Rear Hatch
Bride Bucket seat
Racing Brake Rotors
Brake master cylinder stopper bracket
Hood: Wet carbon
_____________
Pictures of my car when I got it in Okinawa.
2 of my babies
_________
My first AutoX with my Dad!
me and my dads car
_________________
100 Dod
http://www.youtube.com/watch?v=kmUlEOvWofk
_____________
Pulling my Engine
http://www.youtube.com/watch?v=ef0uOeNNf70
____________
My frame pulling Thread viewtopic.php?f=9&t=2138
Okinawa to Virginia AE85 Levin Build
Re: Okinawa to Virginia AE85 Levin Build
where in Oki were you I use to live in Ginowan down the street from Auto shop Turbo
Down in Awase a stones throw away from Nakagusku port
Hey I love the build!! would love to see some engine pics, it sounds amazing. I'm installing some webers and trd cams on my bigport right now, just waiting for my electric fuel pump to show up. do you mind me asking about how much power you're putting out?
I actually have no idea!
Big updates! I went drifting at the track and stopped driving because I lost oil pressure, and this is why.
Found these in my oil pick up screen. on the pump side.
Here is the pump
here is the stuff in the screen
This is really weird, I think when it started to get hot, the rear end of the crank expanded, and the bolts started to walk out. Causing the input shaft to wobble, causing the pilot bearing to implode, causing the bearings to get in-between the flywheel and the crank
discovered this was done to the engine
Purchased a parts washer today, to clean everything. no pics of it yet
This was the only damage on the crank surface
all my parts all laid out
The block is really good, needs the be honed, but no damage thankfully!
Here is the pump
I have other updates I need to post. I will get around to it later.
I pulled my frame, and rewired my entire car, and put a racing dash in!
