The year was 2018. I was a picky little kid. I really wanted to find an ae86 for a project, but I didn't want to settle for anything less then the coveted GTS hatchback. It kind of hurts now thinking about how many "clean enough" SR5's and coupes I ignored. Anyways, after about a year of searching, I ended up finding a single one - some guys clapped out parts car. Of course I said yes! Little me was too blinded by the fact that this mythical car he's only seen on the computer was now right in front of him. It didn't matter that it had fist-sized rust holes in the bodywork, or that it was stuffed with puffy, moist bondo. For $1000, how could anybody say no to a parts car like that?
Only problem is that this wouldn't be a parts car for me. I had to fix this shell. To make things worse, I already had a project car going on at this time too. A similarly rusted out turbo firefly. (geo metro with a bodykit, for you yankees) Because of this, the corolla spent all of this time sitting with damp grass tickling it's undersides. When it finally came time to pull the car in to begin work on it, I was greeted with even more rust then when I initially got it.
Terrible pictures, but it gives you the idea that this car probably wasn't worth fixing. Things only got worse when it came time to strip the car down.
The usual rust in the window frame, with some bonus sunroof leakage corrosion. It was easy to get the glass out for these pictures, because the previous owner used the wrong glue to stick the window in. With one weak pry of a flathead screwdriver, the entire bead of glue broke and my glass fell out. Almost ended up breaking the windshield even more! It's kind of scary considering I was originally going to just get the car running and drive it around for a bit. Should've known better when your working with an absolute deathtrap.
I'm hoping the really shitty resolution isn't making things too hard to understand. You should still be able to make out the massive blobs of brown in those pixels.
Two bad frame rails, with the added bonus of the right side being bent. That rust hole was caused by somebody forgetting to seal off the crunched in corner after somebody paved bondo over it. The inside of the car looks worse, but i'll post pictures when it's time to fix it.
With all of that done, the car was chucked on top of the rotisserie it would spend the next year strapped to. With a diy paint job courtesy of my brother, it was time to start cutting back the layers. I'm still not caught up yet, so i'll try to get the next writing done quickly.
