VQ'ed AE86...nuff said
Posted: Sat Apr 27, 2013 5:37 am
(copy and repasted from a while ago) Hey all names DeVaughn, sum call me devo, black lavender,etc. just wanted to post up alil bit of my build process, on 1/30/2011 I made the move to pull my 4AG motor set and sell off everything in favor of a newer more reliable power plant. Now the focus of this swap was not to make a power house or be the fastest, just to have a reliable motor that fit into the car well. SR20 was a thought but there getting very old and need rebuilding plus the hassle of blowing turbos. 1uz for cheap was another choice but the motor again is getting old and needs simple work but it takes alot to shoe horn it in the car plus the radiator usually ends up somewhere near the front of the car in harms way, the motor is heavier at 390lbs with trans, where the Vq is only about at 313 with tranny, and the 4ag comes in right around 276lbs with tranny, sr was about 328lbs. These are weights pulled off the internet so they arent prob perfect but close enough. Anyway to make a long story short I grabbed the VQ with low miles used, price, avalibilty, fit, great weight and 6speed tranny option. Soooo there she is, stripped old motor, sold to a new and happy owner and new motor delivered and waiting for install.
motor cam from illinois, shes a dirty bird on the outside, needs a pressure washing and scrub down. cant beat it for 900bucks!with harness and accessories.
got a 6 speed tranny local for 400bucks, new unused warrenty unit he had, there not in top demand so he let it go cheap.
mated it up and did a dry fit into the car, not too bad, this is as far as is got till the tranny got wedged in the tunnel lol, alot easier to fit after the firewall and tunnel mod for the tranny.
during the fitting process the fuel rail was very close to hitting the firewall so plus its a non return unit so i modded the rail for better fit and function.
welded some -6AN fittings to the rail and powder coated the rails satin black, you can barely see the new fuel cross over on the front of the rail system now.
powder coated the lower intake,water pipes and started to mod the shifter location to make it shorter.
still need to weld this up
took out the 3in" center section and welded it back together.
picked up a Craword intake cheap, its a good mod for the motor and with a intake spacer it would raise the intake up too much and hit the strutbar.
cleaned up the motor and replaced the old rusty valve cover bolts with stainless units, headers, lightweight flywheel, new clutch and added a oil cooler sandwich plate, Samco hoses and tuneup supplies. Going to work on it pretty hard today and mod the front cross member and steering rack postioning for a lower install.
Stoked to get it back to doing more of this, :sn:
dirty and freshly plasma cut.
fire wall looks alot better than factory.
