Celica ST 1991 rebuild + 4AGE swap
Posted: Thu Dec 19, 2013 4:48 pm
by Floyd
Re: Celica ST 1991 rebuild + 4AGE swap
Posted: Thu Dec 19, 2013 4:54 pm
by joel23
ur car looks good ... ready to see more updates....
Posted: Thu Dec 19, 2013 6:52 pm
by Agent Joe
That's a pretty color! what's it called? what is it off of?
Posted: Thu Dec 19, 2013 7:06 pm
by trigun402
Needs more pictures.
Posted: Thu Dec 19, 2013 8:16 pm
by Floyd
Agent Joe wrote:That's a pretty color! what's it called? what is it off of?
I remember, that I just picked one from the colour chart, but I don´t now it´s name, if it has any
I only have the code, if that helps. 08-02-020.
Posted: Thu Dec 19, 2013 9:45 pm
by Floyd
Posted: Fri Dec 20, 2013 12:24 am
by EJ86
engine shots of this "Celica-rolla"
Posted: Fri Dec 20, 2013 1:54 am
by Floyd
Posted: Thu Dec 26, 2013 2:54 pm
by Clouds
Nice build, man. Keep up the updates!
Posted: Fri Jan 03, 2014 5:48 pm
by Floyd
Posted: Sat Jan 11, 2014 5:43 am
by TORPARTS
great work!
Posted: Sat Jan 11, 2014 8:57 am
by Grant
Wow, great work. I like how you're cleaning up every part you take off or replace.
Is zinc coating expensive?
Posted: Sun Jan 12, 2014 4:07 pm
by Floyd
Thanks for all the positive comments guys
Grant wrote:Is zinc coating expensive?
It´s quite cheap actually. It depends on the weight of the parts you put in the bath. I paid around 50 bucks for everything in the post above.
Posted: Mon Jan 13, 2014 9:14 pm
by Floyd
Posted: Wed Jan 29, 2014 11:48 am
by Floyd
Posted: Sat Feb 08, 2014 8:46 pm
by 1992at180
hey floyd i have a 92 st and i am about to do this same project basically. i have been told that the 4afe has a crank drilled oil spot at 90 degrees and it cannot hold over 150hp safely...have you had any problems since you took it to about 170hp?
Posted: Sun Feb 09, 2014 2:29 pm
by Floyd
engine isn´t finished yet. Still waiting for head assembly, hopefully next week... There is early 4AGE crankshaft inside 4AFE block,(they are all the same, as it is still 4A), so I don´t expect any issues here.
Posted: Sun Feb 09, 2014 4:24 pm
by HingaSPL
Love the engine porn, keep it coming
Posted: Sun Feb 09, 2014 7:36 pm
by 1992at180
ok cool thanks floyd for the response. im changing mine up from yours just a bit tho because im planning on turboing mine next year. so im getting 193t cams, acl race,main and rod bearings, aem ems4 ecu,(im getting new crankshaft ladders and rods just not sure what yet) custom low compression pistons, complete multi layer steel rebuild kit smallport 4age head, rebuilding the c52 transmission with stage2 clutch..and ive already put in a tmw short throw shifter, st suspension rear sway bar, 16 inch motegi rims 205/55/16 fuzion tires, polyurethane bushings, and about to do megan racing coilovers, and new tie rods control arms and trailing arms. then getting the minor body problems fixed and painting it. then getting racing seats eventually with a carbon dipped dash, door panels and center console. hopefully it will all be done in a few years..lol
Posted: Mon Feb 10, 2014 2:54 pm
by stevegolf
Looks great, really like the color you picked.
Posted: Tue Feb 11, 2014 10:47 am
by Floyd
Posted: Wed Feb 19, 2014 7:36 pm
by ariel_86
I'm sure if you're aware, but the ARP stud on the exhaust side, number 1, will interfere with the stock distributor in the head. The ARP stud is longer than the OEM headbolts and will catch on the end of the distributor shaft. Be cautious about that and take appropriate measures.
Posted: Sat Feb 22, 2014 8:16 am
by Floyd
ariel_86 wrote:I'm sure if you're aware, but the ARP stud on the exhaust side, number 1, will interfere with the stock distributor in the head. The ARP stud is longer than the OEM headbolts and will catch on the end of the distributor shaft. Be cautious about that and take appropriate measures.
You´re right, thank you for reminding me
Distributor shaft has to be slightly modified to clear the ARP head stud. However, I´m going to use distributor with stock ecu just for brake in time. After that I´ll switch to DLI setup with coils and fully programmable stand alone ecu with agressive map. I´ve got Master Ignition from IMF Soft.
http://imfsoft.com/en/hardware/zapalova ... i-cdi-v8-0
Posted: Sat Feb 22, 2014 9:31 pm
by ariel_86
Floyd wrote:You´re right, thank you for reminding me
If I can help another member to avoid chewing up an exhaust cam and/or destroying a distributor, then I'm glad to help.
That Master Ignition system looks intriguing. I'm going to spend some time looking over that.
And BTW, love what you've done with your Celica and I'm very excited to see your build progress. Keep up the good work!
Posted: Sun Mar 16, 2014 7:00 pm
by Floyd
picked up the egine last week...
Engine spec:
7-rib block
CR 12:1
early "small" crankshaft
Molnar technologies H-beam 40/20 rods
Wiseco pistons 81,50mm
Custom forged ladder bars
ARP hardware (mains, head, flywheel)
OEM oil pump
Bigport head, (skimmed, ported)
OS valve seats with 7MGTE valves (32mm IN, 27,5mm EX)
1SZFE solid lifters
HKS valve springs
HKS timing belt
adjustable cam gears
Kelford camshaft, 193-B (284° 9,20mm IN, 278° 8,50mm EX)
OEM head gasket
here are some pics of assembled longblock and odher stuff...mostly cell phone quality
Custom aluminium spark plug cover
1SZFE solid lifters
Oil cooler (25-row, 329x175x 50mm), Mocal termostatic adaptor plate
Master Ignition standalone ECU with hardware, coils, T3 trigger wheel and Brisk premium spark plugs
Black Diamond performance clutch with kevlar clutch disk
