Hi, a quick search didn't return any results so hopefully I'm not duplicating this post.
I have been struggling to open my hatch for basically the entire time I've owned the car.  It's always the same story, pull lever, pull hatch up half way, go pull lever again, sometimes that's enough for it to pop open.  Sometimes I would pull the lever with my foot and pull the hatch open with my hands... Well, today I've FINALLY solved that problem.
The spring that's attached to the lever that touches the courtesy light switch and pushes the trunk up was too weak.  I shortened it by about 1/4, reattached it and now when I pull the lever my hatch pops up far enough that it doesn't catch the latch again.  The arrow points to where the lever literally pushes against the latch on the trunk, giving it a little push upwards when you pull the release!
							Hatch latch fix
Re: Hatch latch fix
Nice! I'm having the same issue so I'll be trying this fix out. Thanks!
						- grappletech
Re: Hatch latch fix
So the spring was just a little loose/worn???
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
86 SR5 Hatch Shell
