Anyone Techno Toy Tuning T3 camber plates ?
PDB
Postby PDB » Mon Aug 03, 2015 1:27 pm
Is anyone running the T3 camber plates please ?
I've got a KP60 Starlet but basically the same suspension, I had the stock suspension struts converted to run coilovers and have been using the standard top mounts.
Trying to fit the T3 mounts and I just don't see how they will work, I have emailed them and they sent me this picture back Image
And said the bearing fitted is just incredibly stiff which is why I can't turn it ? Even with it all done up, if I turn the top mount to simulate turning the shock piston is just turning inside the shock housing ?
Any advise please.
Re: Anyone Techno Toy Tuning T3 camber plates ?
Postby totta crolla » Tue Aug 04, 2015 3:05 am
Is the top nut dragging on the top mount ?
Certainly the last two pictures show witness marks of something removing the anodising.
PDB
Postby PDB » Tue Aug 04, 2015 8:31 am
Those marks are from the socket when I was doing up the nut.
Have had it sorted now, the supplied collar wasn't big enough, had to get a couple deeper ones made up.
Not overly impressed though, can only get 1 Allen adjuster bolt in on either side of the shock as the holes in the Starlet chassis are small, I know you don't need a load of adjustment but this is not expected of a $190 top mount :(
ritz
Postby ritz » Tue Aug 04, 2015 9:28 am
Yes, it is very stiff when new. Try harder.
PDB
Postby PDB » Tue Aug 04, 2015 1:54 pm
They have been very helpful to be honest, suggesting I use 2 holes next to each other but 1 without a washer !
Postby totta crolla » Wed Aug 05, 2015 2:46 am
Surely that wants to have a small spacer underneath the bearing and a sleeve nut on top ?
http://www.ebay.co.uk/itm/Top-Mount-TO- ... 0943888114
different thread but you get the idea.
jdm86gtz
Postby jdm86gtz » Wed Aug 05, 2015 6:06 am
The T3 top mounts come with a separate nut and sleeve to go into the bearing unlike the 1 piece Cusco nut/sleeve.
You might have to relieve the strut top a touch to get the other bolts in, the gold bearing housing is probably universal and dictates the sliding area of the red plate. So without using a smaller bearing you are stuck because of the small KP strut top.
PDB
Postby PDB » Wed Aug 05, 2015 10:22 am
Thanks Totta Crolla, that would of been handy, but I had the lower part of my Nylock milled to fit, you just can't see it in the pictures.
Jdm86gtz, I didn't receive any nuts with my mounts :( and yes that was my thoughts too about the mounts, will work, just not as good as I had hoped.
