My brake servo has gone so I decided to remove it
Fitted a techno toy tuning delete plate and a MK1 Toyota Rav 4 master cylinder which is 7/8".
Then removed and drilled another hole higher in the brake pedal, I had read online that no more than 7 degrees higher otherwise it will press down rather than just out.
I have no idea how to work out 7 degrees do had a guess at this ?
Greased it all up but can't test it yet as still waiting on a modded propshaft.
Any thoughts appreciated, hope it was worth the effort!
