AE86 Automatic transmission
tlea
Postby tlea » Wed Jun 09, 2021 7:34 am
Hi. I have a Blacktop that is being fitted to an automatic trans from a ae86 rwd. Little tricky but flexplate is from MR2 for the 8 bolt crank. My question is this, did AE86 autos use a plate like a spacer between the flexplate and crank? The flexplate that came off the blacktop has that plate behind it as well as the reinforcing ring that goes on the bolt side. Spacer is 1/8"
zze86
Re: AE86 Automatic transmission
Postby zze86 » Wed Jun 09, 2021 9:53 am
Never had an auto so can't confirm but on parts diagram, doesn't look like there's any flex plate, just a spacer (32116)
tlea
Postby tlea » Wed Jun 09, 2021 10:07 am
That is perfect, thank you. The 32116 spacer is what I'm asking about. What I'm calling the flexplate is what they call the gear
Postby oldeskewltoy » Thu Jun 10, 2021 7:19 am
tlea wrote:Hi. I have a Blacktop that is being fitted to an automatic trans from a ae86 rwd. Little tricky but flexplate is from MR2 for the 8 bolt crank. My question is this, did AE86 autos use a plate like a spacer between the flexplate and crank? The flexplate that came off the blacktop has that plate behind it as well as the reinforcing ring that goes on the bolt side. Spacer is 1/8"
the flywheel/flexplate bolts are NOT the same as in a regular flywheel bolt........ part# 90105-10048 x 8 is what you need to mount the flexplate
