Idle issues
Nico86
Idle issues
Postby Nico86 » Mon Oct 10, 2022 5:54 pm
Hi everyone im having idle issues with a JDM 16v 4age, it has a USDM MAF set up and i was wondering if this could be the issue because ive already tried so many things to fix it and nothing. Thanks so much guys :D
davew7
Re: Idle issues
Postby davew7 » Tue Oct 11, 2022 4:39 am
Need more info. too high or low idle speed? stalls, hot or cold conditions?
Nico86
Re: Idle issues
Postby Nico86 » Tue Oct 11, 2022 3:14 pm
it was idling too high at first, and then it would idle low when it was cold and then began to idle normally once warm after driving it. but now it is idling higher again and then just straight stalling
Nico86
Re: Idle issues
davew7
Re: Idle issues
Postby davew7 » Wed Oct 12, 2022 5:19 am
That is probably your waxstat located under the TB. First remove the two small water hoses and blow-out lines and block fittings or replace the water lines. If that does not fit it, then you will have to adjust the waxstat. Seach for waxstat adjusting tool and how to dis-assemble the unit. You will have to make an adjusting tool to alter the RPM at cold idle. Before you try to adjust, soak the waxstat in solvent to make it easier to adjust. It does not take a lot to alert the RPM. A .025" adjustment change about 700 RPM on my waxstat. Also when making the adjusting tool, the pins MUST be short or they will bend.
Re: Idle issues
Postby jondee86 » Thu Oct 13, 2022 9:51 pm
Be a good idea to take the waxstat off the TB and boil it to see if it opens first. Then see if water
flows thru the valve to heat the wax pellet, as the water side can get blocked up with crud.
