more suspension issues
				Kuromi_loves_toyota
recently did an MR2 rack swap on my corolla, and until now ive had no issues, i recently broke a tie rod end and decided to replace it with the tie rods from my coupe. i didnt know that the AE86 tie rod ends were longer than the AW11. should i buy a set of AE86 inner tie rods or should i buy a new pair of MR2 tie rods?
									"be creative and live a fun life, and dont be an asshole" KB43VER
						Re: more suspension issues
It should not make any difference using a longer tie rod end, as long as you have enough depth in the threads, to adjust for the change and you have the correct toe in.  I assuming that after adjusting the toe, both sides are going to be very close to the same overall length and the steering rack position has not changed, which could cause a bump steer issue.
ae inner & outer, just keep in mind that one side of the aw11 rack is shorter than the ae rack, so check left to right stops and center from there.
My turd of an 86
20v swapped 86 write-up
						My turd of an 86
				Kuromi_loves_toyota
morgan wrote:ae inner & outer, just keep in mind that one side of the aw11 rack is shorter than the ae rack, so check left to right stops and center from there.
so swap to AE inner and outer tie rods? would i have to switch to AE non power inner tie rods or would i be able to keep my PS outer tie rods
good Q, I forgot to mention that, use the PS
My turd of an 86
						My turd of an 86
Ideally you want the inner balljoint ball centres to be the same distance apart as the AE86 rack.
l would hazard a guess that the balljoint centres are the same distance apart as the track control arm pivot bolt centres.
I might try to measure that sometime.
This got kinda confusing lol
If you use an Mr2 Rack on a AE86 ,
Use AE86 Power steering inner and outer tie rods.
And if your looking for more angle, get yourself a rack spacer.
