intake manifold studs
ae86xy
Postby ae86xy » Tue Mar 12, 2013 11:37 pm
Got one question, I got my smallport head and im about to use the rwd intake manifold with t3 adapter how do you remove that two studs on the intake side as its shorter than a blue top any idea thanks.
KonaTrueno723
Re: intake manifold studs
Postby KonaTrueno723 » Wed Mar 13, 2013 1:06 am
Use a stud remover tool..or.. You can do it the el cheapo way & just thread on two nuts jammed together then extract the inboard nut with a 12mm wrench, counter clockwise..
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
ga_goosh
Postby ga_goosh » Wed Mar 13, 2013 5:32 am
ae86xy wrote:Got one question, I got my smallport head and im about to use the rwd intake manifold with t3 adapter how do you remove that two studs on the intake side as its shorter than a blue top any idea thanks.
the easiest way is to tighten 2 nuts together on the stud. then you can losten the bottom nut and with them locked together woll hold the stud and losen it from its threads
here is a vid for the visual learners.
http://www.youtube.com/watch?v=66ATKL4G04M
I <3 my AE86
4AG Manual
AE86 FSM
MisterJerk
Postby MisterJerk » Wed Mar 13, 2013 6:43 am
or you could do it the redneck way, if you arent planning to use em again, just use vice grips. lol
ae86xy
Postby ae86xy » Wed Mar 13, 2013 9:11 am
Thanks guys
KonaTrueno723
Postby KonaTrueno723 » Wed Mar 13, 2013 5:06 pm
MisterJerk wrote:or you could do it the redneck way, if you arent planning to use em again, just use vice grips. lol
:lol: & those will work really good too..
87 GTS Coupe
