Would the AW11 spacer + AE86 I.T.R offer more steering angle?
Attached some pics to show what I'm on about.
BakaBaka wrote:In the process of fitting my new AE86 P/S Inner Tie Rods onto my AW11 Rack. Just realized the AW11 Manual Inner Tie Rods comes with a 4.2mm spacer. Was wondering if I should use this spacer along with the AE86 P/S Inner Tie Rods or use the original lock ring that came with the AE86 Inner Tie Rods?
Deuce Cam wrote:Don't use the aw11 spacer. It won't increase steering angle because it's not adding length to the rack.
Use the ae86 lock ring, and make sure to stake it to the tie rod once it's installed.
mrbiggsae86 wrote:Is there a difference between using megan inner tie rods for a manual rack that has the spacer built in and the power steering version?
