Binding airmix cable, broken climate control
Tora
Postby Tora » Fri Aug 16, 2013 7:39 pm
So, my air-mix cable has siezed, and forcing the hot/cold switch caused the back bracket of my climate control to break. I ordered a new heater valve cable and installed it, I have a new climate control ready to go, but the airmix cable is not available through Toyota. I've ordered a newer version of the cable, part number per the sugguestion of http://forums.club4ag.com/zerothread?id=6700 but it appears that he lost the cable before he could install it. I was wondering if anyone else has attempted this? Given how cheap the cables are, I'd be amazed if anyone hasn't experienced problems with their climate control yet.
grappletech
Re: Binding airmix cable, broken climate control
Postby grappletech » Fri Aug 16, 2013 9:10 pm
I ordered one also, never had the time to use it though. I also like to use things until its completely broken.
someone has to have done this.
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
BlackStar
Postby BlackStar » Sat Aug 17, 2013 1:50 am
I took my cables and drowned them in WD40, mainly soaking and moving the metal rod in the plastic seeth(or whatever it is called). YMMV
Tora
Postby Tora » Thu Aug 22, 2013 12:20 am
I fixed it yesterday! Not the most difficult project.
1. Order the cable 55909-35030 from Toyota.
2. Cut off the white mounting plastic and make the notches deeper, as shown by Jeff Lange:
3. Drill the cable hole a bit bigger (quite a bit, actually), maneuver the cable into position.
4. Reassemble your under-dash.
BoRoYaSui
Postby BoRoYaSui » Wed Aug 28, 2013 9:48 pm
The climate controls prone to break. After they brake i fixed them with epoxy and glue in some supports in the weak spots. It makes to whole thing feel less sloppy too.
Tora
Postby Tora » Thu Sep 05, 2013 9:33 pm
Yea, you want to change or lube your cables BEFORE they break your climate control's cheap plastic. Mine was irreparable:
BakaBaka
Postby BakaBaka » Tue Sep 10, 2013 3:52 am
Someone needs to CNC a new climate control unit. I'd buy it. I have had it break on me 3 times already.. I gave up after the 3rd time.
Tora
Postby Tora » Tue Sep 10, 2013 2:57 pm
Did you change the lines out when you replaced the climate control? My airmix cable is smooth as silk after this upgrade. I have a new heater valve cable on there, but I'm starting to worry about the condition of the valve itself, so it's next on my list.
yellowsnow4free
Postby yellowsnow4free » Tue Sep 10, 2013 9:36 pm
If you're going to stick with the stock cables you should work some WD-40 into them. Spray some WD-40 into one end then move the cable a bit.
But what I found made the most difference was to lubricate the heater valve under the hood (I'd also shoot some WD-40 into the cable). At that point the airmix lever on the climate control unit worked very smoothly :) This was about a year ago; I need to lubricate the heater valve and cable again.
Now that I have a spare climate control unit, I've been thinking of repairing it and swapping all the cables with updated ones. Just measure them and then hunt in a junkyard for them (I believe Jeff Lange's post gave some more info on what Toyota years / models used this updated cable).
