I wanted to know if anyone has come across this issue? What are my options at this point since its a banjo bolt on the hardline?
Thanks guys!
Jeonsah wrote:vice grips
xorzero wrote:Jeonsah wrote:vice grips
I can try that to take it off but how would I replace that banjo bolt without butting the hard line?
KonaTrueno723 wrote:xorzero wrote:Jeonsah wrote:vice grips
After removing it with vise grips, cut the hard line w/small pipe cutter, remove & replace flare nut, reflare with flaring tool.. Done
Mankow wrote:I ended re-flaring mine because a previous owner stripped mine out, then just cut the line and called it day, so I ended up re-flaring and replacing that flex line with braided SS with AN fittings. Let me know if you want pics or the parts I used, since that flex line may become too short if you cut the hardline and re-flare.
