How to Identify SmallPort/BigPort FPR
F0Bman
Postby F0Bman » Wed Nov 27, 2013 11:30 pm
Can you guys help me out and help me identify which is which?
They look similar and I can't really tell which is which?
Thanks,
F0B
Re: How to Identify SmallPort/BigPort AFR
Postby yoshimitsuspeed » Thu Nov 28, 2013 10:31 am
In my world AFR means air fuel ratio but I don't think that's what you are talking about. Care to clarify?
F0Bman
Re: How to Identify SmallPort/BigPort FPR
Postby F0Bman » Tue Dec 03, 2013 4:40 pm
Sorry about that yoshimitsu. I got the words mixed up. I was requesting about the FPR part numbers. Anyone have experience using the small port FPR and getting success out of it?
Thanks
Postby jondee86 » Tue Dec 03, 2013 6:39 pm
Hey FOB... pretty sure that the bigport and smallport run the same fuel
pressure. So you should have no problems running the smallport FPR on
a bigport rail providing you can connect it... the return hosetails go in
different directions.
AE92 smallport part # 23280-16070
AE86 bigport part # 23280-16020
F0Bman
Postby F0Bman » Tue Dec 03, 2013 8:44 pm
Thanks man.
I keep on reading that guys that run smnallport FPR on smallport swaps always run rich, so I wanted to isolate these cases and find out some real world experiences from other people.
Postby jondee86 » Tue Dec 03, 2013 9:46 pm
Smallport runs bigger injectors than the bigport. So if you run smallport
injectors on a bigport ECU, its gonna run rich.
EDIT: Should have checked with the Club4AG Tech Reference before I opened
my mouth :oops: Tech ref says bigport FPR pressure @ 2.55kg/cm2 and
smallport FPR @ 2.90kg/cm2. That means you do have to be careful which FPR
you use, because if you used a smallport FPR on a stock bigport, it would
overfuel by roughly 14%.
