My results, for whatever reason the forum cutesy.picture off, if you click it pull be able to see he complete result
Jacare wrote:Other clues: my car has a very rough idle. Super high at first turning on. And after warmed up it fluctuates when not in gear. From 1k to about 600 back and forth. Like mini revs.
My booster may also be sucking. It leaks brake fluid where it meets with the master cylinder (which is new) and when I depress the brake at a stand still the revs go up anywhere from 200 to 400
Man it sucks not being mechanically inclined like some of you are. Guess this.car is a good please to start right?
