prepare to laugh....and help
meifert
Postby meifert » Sat Mar 15, 2014 8:49 pm
https://technotoytuning.com/toyota/ae86 ... 86-corolla
Just installed the T3 ultimate rear chassis brace. it works amazing except i overlooked one thing...i left the spare bolted down and welded the front brackets. So now I cant remove the spare. Any ideas on how to get it out without grinding welds? I dont mind cutting a crappy spare tire wheel in half, i just want to try and make it easier than that
1984 Corolla SR5.....banana on wheels
Buddy Club Spec 2 Over axle, T3 Test Pipe, T3 Bomber Bar, T3 Ultimate Rear Brace, Enkei Apache 2 wheels, (Weber carb and Cam not installed)
Cheap, good or fast.....pick two.
Re: prepare to laugh....and help
Postby totta crolla » Sun Mar 16, 2014 3:06 am
:lol: :lol: :lol: :lol: :lol:
Nick94tt
Postby Nick94tt » Sun Mar 16, 2014 6:18 am
Grinding the welds may be substantially easier than trying to knock a wheel and tire into pieces with a sawzall.
You could try deflating the tire and tossing a ratchet strap around it to compress it. Not sure if the wheel itself is small enough to make its way out.
New take on painting yourself into a corner. :D
meifert
Postby meifert » Sun Mar 16, 2014 8:53 am
I am going to cut the tire off today. It's dry rotted anyways, its the original spare that came with the car.
Nick94tt
Postby Nick94tt » Mon Mar 17, 2014 5:58 pm
How'd that turn out? At some point I've taken a sawzall to an empty tire - still not entirely sure why. I can imagine the pita it will be /was with the tire trying to jump around the spare well/bottoming out the blade... :(
milchmann
Postby milchmann » Mon Mar 17, 2014 7:19 pm
There are those fun little metal bands around the bead seat are too. I have had to cut what was left of tires that blew out before. Not fun even when you can get at it easily.
meifert
Postby meifert » Mon Mar 17, 2014 10:23 pm
Rotary tool with a 10,000 rpm cutting wheel I ran out of cutting wheels. Looks like a project for a weekend. My boss thought it was funny as hell when he saw it.
my86mystory
Postby my86mystory » Mon Mar 17, 2014 11:13 pm
This is exactly why t3 should have made that middle bar removable -.-
meifert
Postby meifert » Tue Mar 18, 2014 10:34 am
No. That's why you check before installing things. If the middle bar was removable it wouldnt be as stiff.
tchybrid
Postby tchybrid » Tue Mar 18, 2014 11:07 am
LOL, sorry this made my day. but yes, cutting the spare rim even enough to bend it and yank it out would be best.
Sportmax
Postby Sportmax » Tue Mar 18, 2014 11:25 am
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Pictures or it did happen ;)
meifert
Postby meifert » Tue Mar 18, 2014 11:29 am
How do I post pictures?
Sportmax
Postby Sportmax » Tue Mar 18, 2014 12:21 pm
meifert wrote:How do I post pictures?
I usually put it on a hosting site like photobucket. theres a ton out there.
riddleyo
Postby riddleyo » Tue Mar 18, 2014 6:24 pm
LOL.
Props for having thick enough skin to post your mistake for the world to see. Now show us some carnage pics!
meifert
Postby meifert » Tue Mar 18, 2014 8:32 pm
I will when I get the time.....and figure out my new PC.
my86mystory
Postby my86mystory » Wed Mar 19, 2014 2:00 am
meifert wrote:No. That's why you check before installing things. If the middle bar was removable it wouldnt be as stiff.
+1 for the double checking part
As for the not being as stuff... Strut bars have screws making the bar removable soo I don't believe in it being less stiff if the middle bar was removable. If anything the difference would be too small to make a difference. I had an ueo copy rear hatch chassis brace like yours without a middle bar or a bar connecting the rear points and that was plenty stiff for what it was.
Aside from that looking forward to picks to make my day haha this sh** was hilarious to read
Postby totta crolla » Wed Mar 19, 2014 2:39 am
meifert wrote:I will when I get the time.....and figure out my new PC.
Do not go near the new PC with your welder
:shock:
thanks for the laughs, made my day :lol: :lol:
warnarf
Postby warnarf » Mon Apr 21, 2014 3:30 pm
The easiest redneck way to get it out is....don't. You slide a piece of board or sheet metal over it and put the carpet back :D
95gto
Postby 95gto » Tue Apr 22, 2014 2:06 pm
If you could find some in the right size, you could cut the center bar, remove the spare, and then reinstall the center bar with some roll cage end bungs:
http://www.ebay.com/itm/CBM-11009-Steel ... 2169wt_734
It would give you the ability to use the spare tire well with a minimal and most likely negligable change in brace rigidity.
SidekickChuck
Postby SidekickChuck » Wed Apr 23, 2014 8:11 am
If your house room needs painting, contract it out please:
2001 Carbon Black e39 M5
