7ac build
7ac build
I yanked an engine, 7age, from a mid 90s Corolla. What would it take tuning wise to drop a 4ac head and carb onto it? I also have a cam to send off for a regrind when I get tax return. I dont need alot of power I just want a fresher engine with a little bit more torque. I am dropping a built Ford 347 or 363 into the car when I get money to buy a wrecked donor car to fabricate on.
1984 Corolla SR5.....banana on wheels
Buddy Club Spec 2 Over axle, T3 Test Pipe, T3 Bomber Bar, T3 Ultimate Rear Brace, Enkei Apache 2 wheels, (Weber carb and Cam not installed)
Cheap, good or fast.....pick two.
Re: 7ac build
You mean you pulled a 7afe from a corolla?
http://www.86garage.com/forums/viewtopic.php?f=8&t=2726
http://forums.club4ag.com/zerothread?id=42373
Those two links should give you most of what you need to know for 7ac. If I were you though, I would carb a 4age head and put it on the 7afe block creating a 7age. Better end result all around and close to the same amount of work. Just my opinion though..
Re: 7ac build
rumsawatti wrote:You mean you pulled a 7afe from a corolla?
I would but I need a knee replacement and cannot drive a 5 speed because of that. The 4age requires a maunal transmission to run due to the bellhousing. If I can run an automatic and a 4ag head I will go that route but a 7ac is also a direct drop in.
Re: 7ac build
4age head will fit on that block attached to an automatic tranny. A series engines fit all the same trannies.
Re: 7ac build
MisterJerk wrote:4age head will fit on that block attached to an automatic tranny. A series engines fit all the same trannies.
Even though the automatics have the starter on the driver side?
Re: 7ac build
meifert wrote:MisterJerk wrote:4age head will fit on that block attached to an automatic tranny. A series engines fit all the same trannies.
Yep
Re: 7ac build
yoshimitsuspeed wrote:meifert wrote:MisterJerk wrote:4age head will fit on that block attached to an automatic tranny. A series engines fit all the same trannies.
Yep
ok. I was under the impression that you needed to convert to the GTS manual transmission for any exhaust to clear due to the starter location on the SR5 transmissions.
