I picked up an f20c swap for my rolla. It didn't include the full under dash harness (was cut so i have the pig tail) or the cluster but I'm running a digi dash lite.
problem is I'm unsure of how I'm going to wire. Do I need to wire the under dash in order to pass the immobilizer? would it be easier for me to just buy the under dash harness?
Also I could use a FSM if anyone has one or a hookup that'd be rad
F20c swap
Re: F20c swap
Is HASPORT still around? I haven't seen anything from him in awhile.
ValiantPoe
Re: F20c swap
I think JSP does that conversion.
Re: F20c swap
JSP has stuff for the conversion. Most of it is not on their website though. I would do it myself but the whole clutch issue....
1984 Corolla SR5.....banana on wheels
Buddy Club Spec 2 Over axle, T3 Test Pipe, T3 Bomber Bar, T3 Ultimate Rear Brace, Enkei Apache 2 wheels, (Weber carb and Cam not installed)
Cheap, good or fast.....pick two.
Re: F20c swap
meifert wrote:JSP has stuff for the conversion. Most of it is not on their website though. I would do it myself but the whole clutch issue....
clutch issue?
UCSB Alum
