[img][IMG]http://i1289.photobucket.com/albums/b518/HachiLover86/vacuum_zps6374ead8.jpg[/img][/img]
So yesterday one of the black wires on that vacuum tank thing came undone.
Ever since then when i try and start my car, it just dies. Seems like a vacuum problem.
Could that wire cause this?
Some people said if i dont have AC i dont need it. ( Vacuum tank in picture. )
But when i unplug it and plug the vacuum lines same thing happens the car just dies.
Thanks in advance. I am very confused at this point!
Car: 1986 ae86 GTS.
All stock. No AC
VSV problems
Re: VSV problems
That VSV is not for the A/C, it is for electric load idle-up. It slightly raises the idle when you turn on things like headlights, A/C blower motor, brake lights, etc.
I don't think it should affect the idle enough to stall the car... does it stall right away, or does it struggle for a while then stall?
HachirokuLover86
Re: VSV problems
Its stalls right away.
Yeah i really didn't think this would be the cause either.
Ok then it must be another problem somewhere in the vacuum system.
Thank you very much for the quick reply!
ZINCHOTRAN
Re: VSV problems
I heard there is a separate idle-up for the blower motor. Should be somewhere under the dash. Passenger side perhaps?
