Squeaking Noise when Running
Migorn
Postby Migorn » Fri Feb 08, 2013 8:09 pm
Recently changed my timing belt after it went bad, and now when I start the car there is a squeaking noise. Trying to pin point the source of the squeaking noise and was curious if anyone might have any ideas.
Thanks,
Mig
gzus13
Re: Squeaking Noise when Running
Postby gzus13 » Fri Feb 08, 2013 10:21 pm
Did you replace the timing belt tensioner? The bearing in it can squeak when it goes bad. I'd also take a look at all of the other belts - make sure they are in good condition and tensioned properly. You could also try some belt dressing. It could also be the tensioner pulley for the power steering and A/C compressor belt - take a can of WD40 or other spray lube and shoot it at the pulley shaft when the car is running - if the squeak stops, that is your cause and it will need to be repaired or replaced.
88 AE92 Corolla DX, 86 AE86 Corolla GT-S, 73 TE21 Corolla Deluxe
Psalm 91, 2 Timothy 1: 9-10, Ephesians 2: 8-10
http://www.superhachi.com
grappletech
Postby grappletech » Sat Feb 09, 2013 6:58 am
My squeak came from the alternator not being tight enough. Try what Jesus said first tho since that is what you were particularly working on
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
