Idles lower when cold.
Posted: Fri Mar 07, 2014 8:34 pm
by Tennikee
Wondering if anyone off the top of their head knows whats going on. The car seems to idle at 600 when first starting up, once warm it goes to 1000. Any ideas? Thanks!
Re: Idles higher when cold.
Posted: Fri Mar 07, 2014 8:37 pm
by yoshimitsuspeed
Why does the title say idles higher when cold but the post says it idles lower when cold?
If it idles higher when cold that is normal.
If it idles lower when cold it probably means your idle valve is stuck or blocked off.
Posted: Fri Mar 07, 2014 10:59 pm
by Tennikee
Oops... Lol didn't realize my mistake. Fixed. It idles lower when cold.
Re: Idles lower when cold.
Posted: Fri Mar 07, 2014 11:23 pm
by jondee86
The thermostatic idle-up valve (AAV) is under the throttlebody and
connects to the engine cooling system thru two little rubber hoses.
If the valve is still there (nor removed or blocked off) then both of
the rubber hoses should get hot as the engine warms up. If only one
gets a bit warm and the other one stays cool, then you need to take
a look at the idle-up valve. Best way is to remove the throttlebody
and then unscrew the valve for cleaning or replacement.
If you don't have an idle-up valve or it has been blocked, just raise the
cold idle a bit to say 800rpm using the air bypass screw down the tube
on the side of the throttlebody.
Posted: Sat Mar 08, 2014 6:20 am
by MisterJerk
When I cleaned my idle valve, i found a 5" piece of RTV in it
Posted: Sat Mar 08, 2014 1:13 pm
by jondee86
MisterJerk wrote:When I cleaned my idle valve, i found a 5" piece of RTV in it
Good find... I wondered where that had gone :mrgreen:
