Is it just plug and play or do I need to change some things? il prob be getting a full swap and just
Wondering if I need any other parts to make it run on my sr5
Thank you
4age silvertop into sr5 what do I need?
Re: 4age silvertop into sr5 what do I need?
I hate giving this response but Search it. Google is your friend. There are a Bunch of swap right ups out there. I just finished a BT swap on my 86 and I did enough research to figure it out on my own.
Tweaked can do a harness for you. His harness is pretty much plug and play. you will also need a GTS Belhousing since your going into a SR5.
Lots of research before you start on the swap!!!!
Sportmax wrote:I hate giving this response but Search it. Google is your friend. There are a Bunch of swap right ups out there. I just finished a BT swap on my 86 and I did enough research to figure it out on my own.
for real! this google search literally took 30 seconds.
first step - http://forums.club4ag.com/zerothread?id=6239 to convert the sr5 to gts first
and then - http://forums.club4ag.com/zerothread?id=101899
good luck and post pics
