Coupe rear side moulding part numbers.
evanstewy
Postby evanstewy » Fri Mar 21, 2014 9:25 am
I was trying to find the part numbers for an 87 coupe rear side moulding but all I could find was the one for a hatch. Anyone have the part numbers for a coupe? Thanks.
Jeff Lange
Re: Coupe rear side moulding part numbers.
Postby Jeff Lange » Sun Mar 23, 2014 10:01 pm
You mean for the quarter glass?
Jeff
evanstewy
Postby evanstewy » Mon Mar 24, 2014 7:05 am
Yes
Jeff Lange
Postby Jeff Lange » Mon Mar 24, 2014 11:50 am
Mouldings:
75641-12110 - Front RH
75642-12110 - Front LH
75643-12040 - Upper RH
75644-12040 - Upper LH
75645-12041 - Rear Corner RH
75646-12041 - Rear Corner LH
75647-12040 - Lower RH
75648-12040 - Lower LH
76651-12041 - Front Upper Corner RH
76652-12041 - Front Upper Corner LH
76653-12041 - Front Lower Corner RH
76654-12041 - Front Lower Corner LH
Clips:
75059-12040 - Front (Qty: 6; 3 per side)
75049-12030 - Upper (Qty: 10; 5 per side)
75039-12020 - Lower (Qty: 6; 3 per side)
Rubber Stoppers:
62785-12010 - Upper (Qty: 6; 3 per side)
Jeff
evanstewy
Postby evanstewy » Tue Mar 25, 2014 2:58 pm
Thank you Jeff!
ZINCHOTRAN
Postby ZINCHOTRAN » Sun May 11, 2014 7:30 am
Can we still acquire these from the dealership?
Jeff Lange
Postby Jeff Lange » Sun May 11, 2014 11:16 am
Some, not all.
Jeff
ZINCHOTRAN
Postby ZINCHOTRAN » Sun May 11, 2014 3:12 pm
Someone said to use plastidip??!
Users browsing this forum: No registered users and 29 guests
