MSPNP2 Succes stories?
ToeKnee805
Postby ToeKnee805 » Wed May 14, 2014 10:29 pm
Im trying to finally finish my build and this damn MSPNP from Megasquirt wont start my car :( Im kinda confused as to how to set base timing? And all this trigger angle stuff. Am i supposed to do this all before i even start the car?
My setup: T25, CX Racing Manifold and IC Kit, 440cc Injectors, MAP Setup, GM IAT.
I load the Turbo startup map, convert it to MAP, Jumper my fuel pump. Vehicle is getting spark, and Fuel. It just does not start. I am at a loss and am looking for someone that has had success running a 4AGE off the MSPNP
Re: MSPNP2 Succes stories?
Postby totta crolla » Thu May 15, 2014 12:20 am
What ignition system are you using ?
A spark is a spark is a spark, useless unless it is at the right time.
ToeKnee805
Postby ToeKnee805 » Thu May 15, 2014 5:59 pm
stock dizzy
Postby totta crolla » Thu May 15, 2014 11:17 pm
and yours is a USDM car ?
My memory of the mspnp is that it has pinouts for USDM cars only.
you may have already seen this:
http://www.diyautotune.com/tech_article ... rt_122.htm
ToeKnee805
Postby ToeKnee805 » Fri May 16, 2014 9:12 am
yeah usdm. that writeup is for MSnS. mines MSPNP. fully plug n play to my stock harness
ritz
Postby ritz » Sat May 17, 2014 1:52 pm
is your timing belt aligned correctly?
ToeKnee805
Postby ToeKnee805 » Sat May 17, 2014 1:54 pm
yeah i checked and triple checked and quadruple checked
ritz
Postby ritz » Sun May 18, 2014 1:17 am
how about the distributor alignment?
ToeKnee805
Postby ToeKnee805 » Sun May 18, 2014 11:00 pm
i was off a tooth on the dizzy and i think i got it right now. Its a little tricky to get these dizzys to line up! I justm ostly need help in knowing how to correctly set base timing, and if i do it before or after i start this thing
ToeKnee805
Postby ToeKnee805 » Mon May 19, 2014 10:00 pm
After a few emails back and forth with Russ from DIYAutoTune i found the problem. When i loaded the bas emap, it didnt have injector/fuel values like i thought it would. I told the map i had a 1600cc motor, and 440cc injectors. Played with the dizzy a lil bit and vroom vroom.
MisterJerk
Postby MisterJerk » Tue May 20, 2014 8:23 am
ooohhh yyyeeeaahhh!!!
