How to remove the rear hatch door window seal
RLZ
Postby RLZ » Mon Jun 23, 2014 11:23 pm
How do you guys remove the rear hatch window water seal without cutting it? it's a 86 corolla hatch back, thanks!
Re: How to remove the rear hatch door window seal
Postby jondee86 » Tue Jun 24, 2014 12:41 am
From the outside of the car, work all the way around the perimeter of
the glass, loosening the seal from the adhesive/sealant that will be
sticking the edge of the seal to the frame. Then go inside and using a
putty knife or similar, start lifting the rubber up and over the steel lip.
Apply some gentle pressure from the inside while working around the
glass until the glass and rubber can be removed together.
Use some tape wrapped around the blade of the knife (or whatever tool
you use), to protect the paintwork while you are levering at the seal.
Engmus
Postby Engmus » Tue Jun 24, 2014 6:34 am
I think you mean the rear-glass-hatch seal, not the hatch to body seal.
I personally didn't do mine, but had a shop do it for 50 bucks labor.
They used a fishing line to separate the seal from the body and then popped the entire thing out from the hatch.
Given the cost of the glass, you might just want to shop this one out, even removing the rear hatch all together and taking it somewhere is more preferable to hunting down the glass in good shape.
RLZ
Postby RLZ » Tue Jun 24, 2014 8:33 am
sorry guys, its the hatch trunk door, i want to repaint it thats why, actually i painted it already but failed, i didnt remove the masking tape on the right time, now the paint is dried, when i tried to remove the tape the paint pops out, i should remove the water seal before i paint it :(
marin86
Postby marin86 » Tue Mar 15, 2016 11:18 am
I'm resurrecting this old thread because I was searching for some help on how to remove the hatch seal around the glass and only saw people saying take it to a professional or cut it out and destroy the seal. I decided to give it a go and found it super easy.
tools needed= 1. rope or extension cord
2. 12mm socket and ratchet
step one. remove hatch from car and set on grass or soft surface facing exterior side down
step two. push rope or extension cord under the rubber seal and keep working it under all the way around edge
step three. glass should be starting to come out on its own so just give it a little pressure down on glass and pull slightly on hatch
glass should fall onto grass and you can pick up hatch
