Ok, so im replacing all the rotors and pads on my car (86 corolla gts) so disk brakes front and back. I bought stop tech rotors and have a set of hawk hps pads and the damn things won't fit lol.
I replaced the the right rear rotor and put the brake pads in, then putting caliper back on and the brake pads hit the CASTING, so don't even ask if i pressed the piston because i can't even get to that point.
I have triple checked everything and all the part numbers are correct. I am completely lost on this, has anyone ran into this before? The only thing i can think of is to sand down the pad material, i have a belt sander and can keep it flat, but i don't really want to do that.
Brake Woes
Re: Brake Woes
Read this...
E-brake Adjustment for GT-S Rear Axle - DIY by assassin10000
Take note of the part about winding the piston back in to reset
the e-brake self adjuster.
Re: Brake Woes
I will give that a try, I'm pretty sure that will help. But i think i have to get my rotors turned. They are .03 thicker than the stock rotors, along with the new pads they hit the caliper casting before it even gets to the piston.
I put the new pads on with the old rotors and they barely just hit the piston and that e-brake adjustment would work.
Re: Brake Woes
Also just checked the thickness of my rotors to the FSM standard thickness and it is a little bit thicker than that. So I'm going to get them turned
- gotzoom?
Re: Brake Woes
If you retract the pistons fully, everything should fit. I run Hawk pads and they don't require any mods to get them to fit. If the pads have a little raised bump, it needs to fit into the matching indentation on the piston to stop the piston from turning. Make sure that lines up, as well. That's why he makes the note on lining things up in this picture.
