Greetings,
Has anyone rebuilt the entirety of their AE86's GTS Fuel System?
I want to replace the tank, straps, filler neck, gaskets, fuel sender, pump, lines and any other related parts.
Are most of these things still readily available?
Any information to this goal is appreciated.
Thanks
Rebuild GTS Fuel System
Re: Rebuild GTS Fuel System
You can remove all the paint and rust then repaint the metal pieces.
Or fabricate or source others in better shape.
- grappletech
Well are you wanting to rebuild or replace? There are tons of articles out there for these. Let me know and I'll post some links for ya
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
86 SR5 Hatch Shell
I just replaced 90% of mine 2 weeks ago.
-Brand new Fuel pump bracket/Gasket/screws from Toyota.
-New Denso Fuel pump (oem replacement)
-3/8 Braided stainless/Nylon Hose +swivel ends [You should get 1 of the ends as 90 deg elbow to keep from pinching the frame]
-6AN /Metric adapter (to connect new line to bracket)
-New Fram fuel filter
New fuel tank put in a few years ago when i had a parts car.
*currently using SR5 feed line as my return to tank.
I might do a quick write up if I get a chance to snap the pics.
Do you need to replace the fuel tank? Unless it's leaking you can get a fuel tank restoration kit and clean the thing out and reseal it. I'm actually planning to do this sometime soon myself.
