CEL code 2-8
Posted: Fri Oct 31, 2014 4:17 pm
by ae86xy
Ok can anyone tell what are and what to look for this codes its for my ae86 gts.
I did look and found code 2 which is air intake temp. Sensor where di i find it or is it the coldstart injector
Re: CEL code 2-8
Posted: Sat Nov 01, 2014 1:56 pm
by jondee86
Trouble codes can be found here...
http://club4ag.com/forums/viewtopic.php?f=9&t=13496
If you have a USDM GTS with Air Flow Meter (AFM) then a Code 2 seems
unusual, as you don't have a pressure sensor. Only the non-USDM versions
have a Manifold Absolute Pressure (MAP) sensor.
The Code 8 refers to the Intake Air Temperature sensor which is inside
the AFM. Here is the electrical test procedure...
THA is the inlet air temp sensor, and you need to use a multimeter to
make sure the circuit has continuity and the resistance reading is in spec.
First check the external wiring for breaks and make sure the plug is not
damaged, and is making a good connection.
Re: CEL code 2-8
Posted: Sun Nov 02, 2014 3:04 am
by ae86xy
Thanks man....
All CEL codes are clear. Just cant get the car start
