high beam low beam switch
Can anyone source me a turn signal switch/high beam switch. The one right in behind the steering wheel? I can't find one anywhere, and the one in my car isn't working properly and I can't seem to fix it.
Re: high beam low beam switch
Just what seems to be malfunctioning with your current switch? Does it seem to get "stuck" between high and low beam, leaving you with no lights?
No when the switch is in the high beam position nothing happens. What is supposed to happening when high beams are on on the switch. The little ball bearing thing fell out when I took the plastic piece covering the brass tabs off. What does that even do?
fastginger wrote:No when the switch is in the high beam position nothing happens. What is supposed to happening when high beams are on on the switch. The little ball bearing thing fell out when I took the plastic piece covering the brass tabs off. What does that even do?
The ball bearing keeps the lever clicked into position. I lost mine also. It wont stay in hi beam position, though my hi beam work perfectly
Ah ha! So you lost your bearing hahaha. Just kidding around friend.
You can stop by a bearing specialty place and sort through theirs to find one that fits. Remember to take the switch with you.
