CA Smog Failure. Looking for input
gumby_z13
Postby gumby_z13 » Wed Jan 23, 2013 3:04 pm
Howdy all, Just got back from a year sitting over in Afghanistan and trying to get my car registered. Took it in for the smog this morning and failed miserably (see pic). Looking to see if anyone might have an idea of what would be causing the HC/CO to be so high? The other highlighted fail on there is the timing, it was off a bit.
86 GT-S with a bone stock 4AG.
Two years ago when tested it was
HC - 41 @ 15mph, 18 @ 25mph
CO - .02 @ 15mph, .02 @ 25mph
Head gasket and timing belt changed little over a year ago with new cap, rotor, and plugs as well. Runs like a champ.
Any suggestions greatly appreciated.
Re: CA Smog Failure. Looking for input
Postby oldeskewltoy » Wed Jan 23, 2013 3:29 pm
It doesn't look like a miserable fail... that would be WAAAAY off......
timing off... and you did the head gasket... I'd say check cam timing, and check ignition timing... set both to stock as per the FSM... Check cap,rotor, wires, and plugs, replace filters, and change the oil.... Drive it hard and get it hot... re-check.
Zenki85
Postby Zenki85 » Wed Jan 23, 2013 3:39 pm
Another solution pay a little extra and make that baby pass lol :)
TEAM 'CLASSIC
A 'CLASSICALIFORNIACAR
VitriumGTS
Postby VitriumGTS » Wed Jan 23, 2013 10:28 pm
Post the entire results not just the failures. I'm talking CO2 O2 etc...
Shakotan, Oni-kyan & Hippari a-go-go baby!
Tora
Postby Tora » Thu Jan 24, 2013 3:20 am
Also, it looks like your EGR is blocked, or one of the charcoal canisters needs to be changed. Not sure if that would spike your HC and CO so high.
gumby_z13
Postby gumby_z13 » Thu Jan 24, 2013 11:00 am
VitriumGTS wrote:Post the entire results not just the failures. I'm talking CO2 O2 etc...
CO2
11.16 @ 15, 11.40 @ 25
O2
.10 @ 15, .01 @25
NO
263 @ 15, 234 @ 25
VitriumGTS
Postby VitriumGTS » Thu Jan 24, 2013 2:16 pm
Your cat is dead or the car wasn't properly warmed up at all. Probably a huge fuel leak somewhere too. I'm betting leaking injector/cold start but check to see if the cat is even there.
Do you have any codes? Maybe a code 11 (misaligned tps?). Make sure that is cleared first before retiming the distributor.
gumby_z13
Postby gumby_z13 » Mon Jan 28, 2013 5:55 pm
Just a quick close out on this one.
The culprit was a bad TPS. It was sending a constant WOT signal and dumping fuel causing it to run way rich. New TPS from Autozone and re-timed and the CO dropped from 5.49 to .07...passed with ease .
Appreciate the assistance.
yellowsnow4free
Postby yellowsnow4free » Mon Jan 28, 2013 9:15 pm
My car failed smog the first time.
Check your timing, do a tune up with new spark plugs (pay a little extra for ones with a "hotter" spark), and get a new oxygen sensor.
That did it for me :)
Good luck!
VitriumGTS
Postby VitriumGTS » Tue Jan 29, 2013 10:07 am
bad tps leading to fuel dump? Damn, I was pretty close! lol
sekang0
Postby sekang0 » Sat Feb 09, 2013 2:15 pm
good post! Mine seems to be running way rich too. O2 levels were super low like urs. I still need to clean out EGR and tighten exhaust mani cuz theres a leak, but I think I'll try a new TPS also.....
'85 GT-S project since 2010
