my 16v 3rib blue top is old and tired and is in need of a swap out. ive sourced a 16v high comp red top motor that i may just pick up and drop in. now me being the kind of person who scowers the interwebs looking for all questions and angles before starting, i have a couple of questions for the conversion.
i already know i have to press in a pilot bearing for the rwd, and ill need the T3 small to big port adaptor to use the blue top tvis intake mani OR have the 16v high comp intake mani re-welded to have the TB facing the other way.
no big deal and that all makes good sense to everyone =]
now what i looking for is the coolant routing, since its a front wheel drive motor, i can only assume the coolant routing needs to be switched up a bit.
also, ive read that somewhere that if i had planned to use the high comp injectors, fuel rail...etc...i would need some sort of resistor bypass...??
^these two things are what im needing answers for. now before you guys go on with your "go search noob" or the "this has been covered so many times" crap, just to let you guys know, i have gone and searched on every forums i could find 4age/toyota related and ALL of them either give vary brief info on the conversion or all say the above mentioned stupidity or even reference the OP of that thread to "hit up Club4AG". lol
and since all of you know since the site came back up, all that awesome info is now gone. i hope it comes back but until then everyone either says to go search, and all searches say to hit up C4AG.
its find all this info or just source me a 7rib block, and the 16v 18mm high comp pistons and use the 3rib crank and rods, some big port head work, some cams, 4.7 final, lighter flywheel, maybe ITB's, and aftermarket managemnet and call it a day
still weighing out the high comp blue, or high comp red builds
also if you have opinions on why either build would be more beneficial then the other, lmk.
goal is a good DD, with autoX and drift practice setup.
