Deuce Cam wrote:That screw mount is just a plastic pop clip. Squeeze the tabs on the backside with some pliers and pop it out from the metal bracket.
IIRC the grill mount brackets were different on zenki (1984-1985) and kouki (1986-1987) models. (I'm pretty sure the mounting holes are closer on the kouki models and farther apart on the zenki models.)
Since yours are different I'm guessing one of your headlights has been changed. The proper solution is to get a right side headlight with the correct bracket. However, if you modded the bracket or grille you could probably make what you have work.
Thanks Deuce Cam. I guess I'll have to find a kouki driver side headlight.
I just bought the trueno badge but there was no metal bracket or a pop clip. This is the back of the emblem
And this is the back of it on the bumper
What does the clip look like? Anyone know where I can find one? I have searched all over the web and this forum and I am really surprised that I cannot find photos or anything that shows how the trueno badge stays on. It feels pretty secure without the clip but I really don't want to risk losing the emblem. Thanks for the help.
