SR5 and GTS gas tank use same mounting stuff?
Posted: Thu Jan 29, 2015 9:59 am
by dinkers542
Swapping a GTS gas tank into my SR5 and dint know if I needed to reuse the mounting stuff from the GTS or if my SR5 stuffwould work.
Thanks in advance,
Dinkers
Re: SR5 and GTS gas tank use same mounting stuff?
Posted: Thu Jan 29, 2015 8:13 pm
by jondee86
Tanks are the same size and shape, so whatever fixings you
have for holding the tank to the car will work with either one.
You will need to swap the GTS pump bracket out for the SR5
fuel pickup... drops straight in with the same gasket and screws.
Posted: Thu Jan 29, 2015 8:28 pm
by Moto_Club4AG
Make sure you hit the bottom of the tank with a rubber mallet upside down, and rinse out the inside. Old tanks usually have tons of flaky rust inside and cleaner you have it, the less stuff that will give problems at strainers and fuel level gauges sensors.
Posted: Thu Jan 29, 2015 9:05 pm
by dinkers542
jondee86 wrote:Tanks are the same size and shape, so whatever fixings you
Do I still need to do that if im doing a full gts swap or only if im using a GTS tank withthe 4ac?
If they are the same size and shape is there any reason that I should be using the GTS tank over the SR5 one?
Posted: Thu Jan 29, 2015 9:09 pm
by dinkers542
Moto-P wrote:Make sure you hit the bottom of the tank with a rubber mallet upside down, and rinse out the inside. Old tanks usually have tons of flaky rust inside and cleaner you have it, the less stuff that will give problems at strainers and fuel level gauges sensors.
Wouldnt have thought of that! Do you have a suggestion on what kind of cleaner to use?
Posted: Thu Jan 29, 2015 9:21 pm
by jondee86
If you are doing a SR5>GTS conversion you need to use the
complete GTS tank, because you need the EFI fuel pump that
lives inside the GTS tank. You will also need the GTS fuel, vent
and return hard lines.
Posted: Thu Jan 29, 2015 11:17 pm
by dinkers542
I have all of it. I bought a GTS shell and have been stripping it over the last 4 days
Posted: Fri Jan 30, 2015 8:10 pm
by dinkers542
jondee86 wrote:If you are doing a SR5>GTS conversion you need to use the
Since they are the same shape can you put an efi fuel pump in the SR5 tank?
