AE86 RWD Carrier Bearing (Driveshaft) Replacement Question
genki86x
Postby genki86x » Fri May 08, 2015 6:18 pm
Hey all,
I have taken my old carrier bearing off of my driveshaft and replaced it with the new. My only questions are:
1. Do I need to put grease anywhere?
2. The nut that holds it on had a notch to punch in. I punched this out before I un-tightened. Can I reuse this nut, or should I try to get a new one? Do I just punch the notch back in?
grappletech
Re: AE86 RWD Carrier Bearing (Driveshaft) Replacement Questi
Postby grappletech » Fri May 08, 2015 11:11 pm
I would personally buy a new one. But it wouldn't hurt to throw the used one in until you make sure all is good.
87 SR5 Coupe Shell. (Sold)
86 SR5 Hatch Shell
86 GT-SR5 Coupe 20v Swap
Postby jondee86 » Sat May 09, 2015 1:27 am
If it is a sealed bearing (and I would be surprised if it was not) then it
will have all the grease it needs already applied by the manufacturer.
Torque the nut up and then punch the edge back into the groove to lock
it in place. It looks to be in good condition, so no need to replace it this
time round.
