RHD turn signal switch on LHD corolla
ericteti
Postby ericteti » Mon Oct 05, 2015 8:41 pm
Hey guys,
Is it possible to run a RHD turn signal switch, on a LHD corolla? I don't have cruise control, so theres no stalk in the way. I figured this would be the easiest way to hook up my Kouki turn signals natively. If not, I'll have a conversion done to my switch.
Thanks!
Re: RHD turn signal switch on LHD corolla
Postby jondee86 » Tue Oct 06, 2015 3:33 pm
I'm having trouble visualizing why you need to change the switch if
you already have a working LHD switch :? A left turn is still a left turn
regardless of which side of the car the driver sits. So why would the
Kouki signals not work just the same as Zenki signals ?
Changing the switch over seems unecessary unless there is something
that can't be fixed by maybe swapping a couple of wires over.
morgan
Postby morgan » Thu Oct 08, 2015 7:01 am
its not the switch that's the problem, im assuming you mean USDM to JDM signals. IF that's the case, its the wiring that needs to be done, the switch wont do anything for you. google the conversion, theres plenty of write-ups around
My turd of an 86
20v swapped 86 write-up
Postby MisterJerk » Thu Oct 08, 2015 7:39 am
I do believe rongfk makes plug and play conversion for this.
