Hey guys,
So my 1984 AE86 Sr5 keeps blowing the 7.5 amp gauge fuse in the driverside kick panel. I cleaned the main grounds in the engine bay and made sure they had a good connection. I also replaced the climate control due to a lever being bad. The heater seemed to be working and then the fuse decided to blow again a few days later. Does anyone know where I should start? When the gauge fuse blows, my cluster does not work at all either.
Thank you
Vic
AE86 Heater wont turn on / keeps blowing fuse
Re: AE86 Heater wont turn on / keeps blowing fuse
Sounds like a short to power. Possibly anything before the load. Ive seen small exposed copper wiring rubbing against anything metal and boom! blown fuse. Remember has to be the power side of the fuse. If its a short to ground, no fuse would blow, its just completing the circuit a different way. Anyone correct me if I'm wrong Try looking up the electrical wiring diagram for the circuit of the Gauge fuse. Ill try to find it myself.
BRRROOOOOM BRRRRRROOOOOOOOMM! "4AGE ENGINE"
Jeonsah wrote:Hey guys,
Thank you
Vic
ever figure this out man? just started having the same problem..
Sounds like the fan has seized or got stuck, the motor will continue to draw power but it will eventually blow the fuse.
totta crolla wrote:Sounds like the fan has seized or got stuck, the motor will continue to draw power but it will eventually blow the fuse.
Yeah not really.
think I solved my problem. somehow or another the wiring to the fuse block in the driver side foot area got f'D up! for me it was the bottom plug but on the backside of the fuse block so you have to remove the fuse block to get to that side i just gave it a layer of electrical tape and so far so good! will update if anything changes
Thanks for the responses guys. I havent looked into it much more. Just decided to let the car sit for a bit while I fixed other things on the other AE86. I will try the fuse box thing tomorrow. That would make sense because I was messing with the driver side kick panel fuse box a little while ago.
