Starter Bolts
Posted: Sat Feb 27, 2016 8:45 am
Good morning,
I misplaced my starter bolts when I removed my T50 to take it apart and make one good T50 out of three transmissions. I did a quick Google search and also a search on the forum.
Does anyone know the specifications on the starter bolts? Length, thread pitch and diameter. Thanks to anyone that can help me out. I have driven a couple years without fifth gear and recently I was only able to get the car in reverse when it is pointing uphill.
Now it has a Cusco transmission mount. Later I will install the Cusco engine mounts.
I used my caliper to determine the length and the diameter. Then I took the starter into Ace Hardware and bought two flange bolts.
M10
50mm
1.25 pitch
M10
50mm
1.25 pitch
