Doing my sr5 to gts conversion and working on the exhaust now. What benefits/ downfalls can i expect if i just cut it out and replace it with a straight pipe? Ex. Rough idle, loud car syndrome, poor or better gas mileage, more hp?? I have removed my egr system also.
Also if i were to keep it there is a small tube coming out the side of the catalytic converter and it has been cut off. Where would this need to go to?
Thanks for your response.
Catalytic converter- to remove or not to remove??.....that is the question.
Re: Catalytic converter- to remove or not to remove??.....that is the question.
Post pic of said tube on the cat.
What headers and cat back are you using?
The exhaust will be a little louder overall without the cc. Imo top end sounds better without it (more rippage); however, low/mid range power, and throttle response is better with a cc.
Interesting, I have no idea what that is. Mine as well leave it if you can seal the other end.
Deuce Cam wrote:Interesting, I have no idea what that is. Mine as well leave it if you can seal the other end.
Thanks for the reply...yeah...i guess I'm just going to Crimp it off. Hopefully my car won't explode...hehe....j/k.
