A/c system from an sr5 work with a 4age 16v?
notnilc20
Postby notnilc20 » Sat Jul 16, 2016 5:16 pm
As some may know I am in the midst of doing and SR5 to GTS conversion and I'm trying to fit an AC system back in the car. I have a 4age 16v 3 rib block. Will I be able to use all the ac lines and components from an SR5?
Ps.... I know the compressor uses a different pulley but other than that are there any other differences?
I did search but came up with several answers and wanted to come here to ask the experts. thank you
Grant
Re: A/c system from an sr5 work with a 4age 16v?
Postby Grant » Mon Aug 01, 2016 6:51 pm
The main differences are the clutch pulley, and the wiring harness (which is a pretty large difference). The A/C computer board inside the A/C evaporator unit is different, the harness that plugs into the evaporator and into the under-dash harness is different (the 4A-GE wiring has some extra relays).
http://files.aeu86.org/manuals/ewd-ae86 ... parrot.pdf
Download that PDF and take a look at the wiring differences. I believe the hard lines and condenser/evaporator units are all the same between the models.
