My AE86 has a redtop with MAP setup and lately has been having issues when I rev passed 3000 rpm. When driving about 3200 rpm and letting off the gas before reaching a stop sign the motor would shut off. After starting it back up, I need to feather the gas at the stop sign since it won't idle at all. I had another enthusiast drive it around to see how it compares to other 86's and said it lacks power in the low end. Been a member since 2005. Had this 86 since 2007.
What the engine looks like for reference:
Things I’ve done to remedy the issue:
-New battery
-New spark plugs
-Replaced fuel inlet bolt
-Adjusted TPS
-Adjusted IACV
-Checked timing and distributor
-Inspected clutch
-New cat converter
-Checked vacuum leaks and replaced caps
