Pic Inside.....help identify this part?
notnilc20
Postby notnilc20 » Sat Jan 14, 2017 7:55 am
I know it's the fuel injector resistor but what car is it from? It was in my box o' parts. I ask because it has 2 plugs on it....not the typical 1 plugger. Thanks.
notnilc20
Re: Pic Inside.....help identify this part?
Postby notnilc20 » Sat Jan 14, 2017 4:39 pm
Here's another part in the bin...looks like some kind of a crank or timing sensor.....might be from a 20v as it was with the other 20v parts....any ideas?
Jeonsah
Postby Jeonsah » Mon Jan 16, 2017 5:50 am
1st one is a resistor box for the 16v 4age largeport AE86. Not sure what the second one is. Dont have that part on my BT 20v.
notnilc20
Postby notnilc20 » Mon Jan 16, 2017 11:26 am
Jeonsah wrote:1st one is a resistor box for the 16v 4age largeport AE86. Not sure what the second one is. Dont have that part on my BT 20v.
Thanks for reply....but why does it have 2 plugs? All the ones i've seen including one on my car has only 1 plug.
morgan
Postby morgan » Thu Jan 19, 2017 9:34 am
the 2 plugs could be from something like a v6 or v8? the 2nd looks like a sensor from a 1zz or something, cam angle sensor though for sure. do you have p/n's on anything?
My turd of an 86
20v swapped 86 write-up
notnilc20
Postby notnilc20 » Thu Jan 19, 2017 12:25 pm
morgan wrote:the 2 plugs could be from something like a v6 or v8? the 2nd looks like a sensor from a 1zz or something, cam angle sensor though for sure. do you have p/n's on anything?
Thanks for the help......no part numbers on anything...maybe if i cleaned the fi resistor box it might reveal a part number but the sensor does not have a part number. Thanks.
Postby jondee86 » Thu Jan 19, 2017 12:37 pm
Google says this....
Toyota HiLux Pickup Truck 4Runner 22RE INJECTOR RESISTOR ballast EFI 28515-28030
notnilc20
Postby notnilc20 » Fri Jan 20, 2017 6:06 am
jondee86 wrote:Google says this....
Oh nice! And a part number to boot. Thanks....now for the sensor.
4agshoob
Postby 4agshoob » Sun Mar 12, 2017 9:47 pm
The sensor looks like a cam or crank sensor from a1uzfe.
4agshoob
Postby 4agshoob » Sun Mar 12, 2017 9:48 pm
Leaning towards crank sensor though. Seems i remember it due to it being held in by 1 10mm bolt.
notnilc20
Postby notnilc20 » Tue Mar 14, 2017 10:08 am
4agshoob wrote:Leaning towards crank sensor though. Seems i remember it due to it being held in by 1 10mm bolt.
Yeah I was thinking it was a crank sensor but didnt know from what engine...1uz you say? Thank you very much for the info.
