How to put a 4age into a 1987 Toyota Corolla SR5?
arvin429
Postby arvin429 » Wed Feb 22, 2017 11:52 am
I bought a 1987 Toyota Corolla SR5 for a couple hundred. It was a good deal so I said why not. It s extremely rare to find an ae86 in New York. A GTS ae86 is even harder. I m not looking to change the rear end. I just want to put a 4age into my SR5. Just a 16 valve. What do I need? List everything needed for the swap. Also anything I can reuse on the SR5 would be great to know. I want to reuse all my sr5 harnesses in my car except for the engine harness. I also heard of people reusing the sr5 gas tank and fuel lines. I also heard of running an external pump. How do I do that? How do I wire in a Pump relay since I am keeping the sr5 harness? How do I wire in the 4age into the sr5 harness? How do I use the old sr5 fuel lines as fuel return lines? Please any help would be great. I tried looking for answers to all of my questions but I got no help.
Thank You!!!!!!!!!!!
Re: How to put a 4age into a 1987 Toyota Corolla SR5?
Postby jondee86 » Wed Feb 22, 2017 12:21 pm
At the top of this forum (just a few lines above your post) you will see the FAQ.
This is a library of Frequently Asked Questions, and if you browse thru the topics
listed in the FAQ you will find answers to most of your questions.
arvin429
Postby arvin429 » Wed Feb 22, 2017 12:51 pm
I tried, but still nothing. I just need help, so please anyone with anything to say about helping, please help
scalpel
Postby scalpel » Wed Feb 22, 2017 2:56 pm
I usually wouldn't say anything
but
you can literally google sr5 to gts conversion ae86 and find many articles/threads and 20v swap etc and even a list of everything...
arvin429
Postby arvin429 » Wed Feb 22, 2017 3:09 pm
I don't want to convert my SR5 to A GTS. All I want to do is put a 4age into my SR5.
scalpel
Postby scalpel » Wed Feb 22, 2017 3:24 pm
and you can find out how by reading those threads.
edit:
the 2nd link on google
http://forums.club4ag.com/zerothread?id=6239
1st link
http://www.hachiroku.net/sr5togts
arvin429
Postby arvin429 » Wed Feb 22, 2017 8:22 pm
I want to only use the engine harness. I want to use the stock SR5 dash harness
ToeKnee805
Postby ToeKnee805 » Thu Feb 23, 2017 1:43 am
god damn new guys dont want to do any research. This is why our forums are dead lol
SgtRauksauff
Postby SgtRauksauff » Thu Feb 23, 2017 8:26 am
the MAIN difference between sr5 and GT-s *IS* the engine, and supporting systems (fuel, electrical, control...)
So reading through those howtos on how to convert the SR5 will give you the information that you need. That information will give you the context on what you need to do, and what you need to change for your own individual project.
Since no two cars are the same, and no two builds are the same, do not expect cookie-cutter solutions to every single task. By learning the info in those other how-tos, you will learn how the different systems integrate in the car, and then be able to answer those questions.
since the 4AGE uses a different ECU than the 4AC, and the ECU is located inside the car, you will need to modify your existing dash harness. So I recommend you get a wiring diagram for both versions of the car (available from searching forums and google), and decide what wires you want to connect where. Do I know where those documents are? Nope, but I have searched and read them before. So I am not going to give you a direct link, when you should be able to find that on your own.
bottom line: RESEARCH IS PART OF THE PROJECT and should be done by the person doing the project, otherwise that project ends up a pile of uncompleted junk in a garage that you sell to someone else for dirt cheap just to get rid of it because you're frustrated and have already bought a Cruze because it's already the best car ever and doesn't need modification, and helps you get to more places to find more pokemons.
arvin429
Postby arvin429 » Thu Feb 23, 2017 1:49 pm
Thank you for explaining it to me
