oem lsd problem! help!
colingchambers93
hey guys im having a pretty big problem with my differential at the moment wanted some opinions on what it could be. ok so after i did a burnout it started to clunk(almost slip) when i let on and off the gas. and also when i go around corners the clunking continues through the corner and sometimes going straight. the noise is coming out of the rear diff housing and is strongest around the axles. and also its not acting as a limited slip anymore. and guesses?
- HASport AE86
Re: oem lsd problem! help!
probably broke an axle
colingchambers93
it still drives tho. would it drive with a broken axle? and i started it in the air and put it in gear and both wheels spun
KonaTrueno723
As HASport said or the differential..I wouldn't drive it if I were you. Drain the diff oil..the drain plug is magnetized, & hope there's no chunks of metal stuck to it.
87 GTS Coupe
72 Blown 6-71 Pro Street Vega
87 GTS Coupe
colingchambers93
i already pulled it out and a part. i snapped the carrier in the spiders gears. the block of metal that holds the outwr geard in place sheared right off
