Quick question about manual rack conv.
Posted: Sun Feb 26, 2017 3:28 pm
by CloudStrife
I'm just now finishing up the manual rack rebuiild from an AW11, but having a problem fitting the boots.
I got P/S AE86 boots on Ebay, but there is too much of a gap on the larger diameter end (towards the inside of the rack).
I swear I'm supposed to use a P/S boot and not the AW11 Manual rack boots as they won't fit.
Very confused..
Any ideas?
Ian
Re: Quick question about manual rack conv.
Posted: Sun Feb 26, 2017 4:08 pm
by CloudStrife
Also, my "cap/tension screw" is backed out quite a bit. Usually, you only see 2-3 threads, but I see 6-7.
I tightened it down until there was no play, and I can move the pinion by hand (kinda) with ease. Am I supposed to torque it down even more? The BGB says that the pinion should have 2-3 ft. lbs of resistance I believe, which should be easily moved by hand correct?
Posted: Mon Feb 27, 2017 1:26 am
by totta crolla
Aw11 boots don't fit the AW11 rack, is that what you are saying ?
Pinion adjustment is critical and no, it should not be easy to turn by hand. Take it to a shop to have it setup correctly.
Posted: Mon Feb 27, 2017 1:42 am
by CloudStrife
Nah, I got Power Steering boots which are for the AE86, and tried to put them on the AW11 manual rack. I swear I read you needed p/s rack boots for the AW11 manual rack conversion when using AE86 P/S inner/outer tie rods.
That would be kind of lame to take it too a shop after all the work I've done myself. In Assassin's write-up, he says to "Snug down by hand & wrench until the rack gear/shaft has no lateral (forward/back & up/down) play, but moves left and right with no catching and/or binding. "; I am probably just going to experiment with this, but I wish there was more info.
Thanks for the reply totta
Posted: Mon Feb 27, 2017 3:56 am
by totta crolla
All the info. you need is in the fsm / bgb and there are no short cuts to doing it right. When the steering rack fails you crash that is the reality.
The power steering rack housing is completely different to the manual rack housing and the boots are not interchangeable.
Posted: Mon Feb 27, 2017 5:51 am
by Jeonsah
AW11 boots.
Posted: Mon Feb 27, 2017 12:22 pm
by CloudStrife
Lol thanks totta.
Thanks Jeonsah,
For anyone wondering, these Amazon boots should do the job for the AW11 rack.
https://www.amazon.com/gp/product/B000C ... UTF8&psc=1https://www.amazon.com/Beck-Arnley-103- ... TQ36XB5G65
Posted: Thu Mar 02, 2017 9:51 am
by CloudStrife
Just put on the AW11 boots. It wasn't really an exact fit since I was using aftermarket Megan inner tie-rods, which have a bigger ball joint housing. It'll go on, just make sure you grease the outside of the ball joint housing a little and work it over.
The Amazon boots worked well, much cheaper than the dealer option at ~30 bucks a pop.
Posted: Wed Mar 29, 2017 3:44 pm
by assassin10000
A quick google will get you a copy of the fsm which has the specs. When I first did it I did not have the tools to setup the rack to spec and went by feel (not normally recommended), but I'm fairly mechanically inclined and have had no issues.
Since that write up I've bought & made the tools to 'do it right'.
Its ae86 Manual rack boots or aw11 boots you needed, as you found out.
Andrew
