Removing the rear quarter window trim on hatchback
Is there a writeup or vid somewhere on this? I want to remove these during paint prep but im scared to death about breaking them. I have the inside removed down to where I can see the screws in the clips. But there is nowhere to unscrew anything else....thanks for any help.
Re: Removing the rear quarter window trim on hatchback
You can see what the window clips look like in this thread...
http://forums.club4ag.com/zerothread?id=77475
And a bit more information here...
http://jp-carparts.com/images/parts/161 ... 3_0001.png
AFAIK the exterior trim just snaps onto the clips. You should be able to lever them
up with a thin blade like an old school putty knife. But I never had to take mine off
so better get a check from someone else with experience
jondee86 wrote:You can see what the window clips look like in this thread...
Hey Jondee86.....thanks for the links. I ended up just going for it....it's not too bad....the top and side part snaps off but the bottom piece slides off the clips....i took some video and will post a video "how to" soon.....maybe I'll make the diy stickies here?
Yeah they just clip right into place and the removal isn't hard either. I did however add some industrial caulk under the trim to create a better seal between the trim and the window because I was getting some water leakage through one side.
